I'm getting some weird behaviour with 4.52 using Mackie Control to write volume automation moves. Becoming very frustrating and time-consuming to fix (and makes me look bad... you know, you champion DP over ProTools, then the basics suddenly stop working).
Imagine you have an entire track where the fader position is constant. You're happy with the level of that track... except in one section where you want a lift for a while.
The automation appears in the graphic editor as a flat horizontal line.
You put the mixer channel into "Touch" automation mode and hit play.
When the section you want to lift comes along, you grab the fader on the MC, slowly raise it to the new level, keep it there, then fade it back down to the original level (or thereabouts). Release the fader. Press stop.
If you watch the graphic editor as you do this, you see the new automation points being written in as you move the fader. Because we're in "touch" you know that when you release the fader it should drop to the previously written level. So as you move the fader, you are "chasing" an automation point, sitting at the original volume level, along the automation line to the right.
However, at some random moment (usually when you're fading back down) DP writes a spurious automation point just AHEAD of the playback wiper, at a possibly random level. You're now chasing this new automation point along to the right. You're still writing data, but now when you release the fader the level will jump to this new level instead of the level that was there before.
I hope that makes sense. I can post screenshots of what happens if it helps.
Basically, every time I write any automation with the Mackie, I have to get in there and tidy up all the "out points" on-screen, because I can never be sure where my levels will have been left. (sings circus clown theme tune).
This kind of stuff also happens in Trim modes, with even more confusingly unusable results. Writing moves in Trim is now an exercise in futility.
It only occurs using the Mackie to write fader moves - if I move an on-screen fader, everything works fine (although this "solution" defeats the object of having the control surfaces). It also happens regardless of which MC fader I'm using, so it's not a hardware weirdness on the Mackie.
I don't recall having this problem before the DP4.5 upgrade. I'm on DP4.52, OS 10.3.8, MIDI Driver 1.3, MIDI Express 128, Dual 2G G5.
Help! Ideas? This is one of those moments when you start wondering if you should put a big sheepskin jacket on and buy PT
Thanks. Paul.
