L.A.M.E. living up to its N.A.M.E.
Buzz Mando
Post by Buzz Mando »
Hi,
I'm trying to burn an MP3 CD, and when I choose that as an option, it tells me to get LAME. This I've done, downloading vs. 3.97 and installing it about 6 times tonight and it keeps telling me to get LAME.
DP help said another way I could do it was make it into a quicktime movie, based on the soundbytes. I did that, but it is a recording of a speech from a cassette tape that I was able to clean up considerably using DP's plug-ins. All of those improvements were lost, as well as the fact that I spliced 3 separate sections on the tape into one long performance, now it's back to 3 separate quicktime movies.
How do I make a decent MP3 using DP 5.12?
gatito25
Post by gatito25 »
Hi
you can finish your project as a .wav or .affi and the open the file with itunes, itunes have a very simple tool to convert the file to mp3, this will preserve all your file settings all effect
hope this helps :)
i know l.a.m.e can be a pain.
zed
Re: L.A.M.E. living up to its N.A.M.E.
Post by zed »
--OR--
You could save yourself a lot of trouble and spend $32 on Audio Hijack Pro: http://www.rogueamoeba.com/audiohijackpro/
This dandy little program will capture audio from your DP project (or anything else that outputs sound in your computer), and allow you to save the file in a wide range of formats. The quality of the resulting audio files seem to be as good as anything that is generated from within DP itself, so there is no degradation. And you can quickly mix a track without having to render effects or convert MIDI tracks to audio.
This is definitely your easiest way to get a quick Mp3 of what you are hearing in your project.
sdemott
Post by sdemott »
Did you install the L.A.M.E. Framework into /Library/Frameworks or ~/Library/Frameworks? It seems to like to be in the former where DP is concerned.
And are you sure that whichever directory you dropped it into has not had any permissions altered?
Those are my first 2 thoughts.
L.A.M.E. works fine for me.
-Steve
Not all who wander are lost.
gearboy
Post by gearboy »
Though I love Audio Hijack Pro, the L.A.M.E MP3 converter is the best that I have heard. Do yourself a favor. Don't export from DP as MP3. Just don't. Export in a "full-resolution" format, and then take it down to MP3. We're talking like 2 extra minutes here.
Use this:
http://www.macupdate.com/info.php/id/8837
It's a little L.A.M.E. encoder for iTunes. Sure, iTunes does MP3, but it sounds horrible in comparison to the L.A.M.E encoder. Install this, learn the code to get the settings you want. Export from DP as WAV or AIFF, Edit if needed, drag into an iTunes playlist, and then click "import" on the L.A.M.E for iTunes program and it will automatically import from the current iTunes playlist and drop it back into a "L.A.M.E. import" playlist.
Simple, plus you have a high-res master as well.
Jeff
OS 10.4.11 - G5 Dual 1.8GHz, 3GB RAM / Mac PB G4 1.5GHz, 1.5GB RAM / Apogee Duet / MOTU 828mkii w/BLA Analog & Clock mod / MOTU DP4.61 / Live5.2 / Peak 4 & 5 LE / Izotope Oz3, Sp, Tr / Waves Ren Max / TRacks, Miroslav / NI Komplete 5 / GF impOSCar, MiniMonsta, M-Tron / Automat / Nomad Factory Vintage Studio Bundle / apTrigga / Audio Hijack Pro
My recording blog: http://www.ipressrecord.com
There's a lot of advice here, but I don't see the link to the LAME framework installer that ALWAYS works. Everyone who has used this installer has said it worked for them. Give it a try (and remove others, if you can).
WARNING: This link downloads the installer:
http://www.ktunes.net/downloads/LAME.zip
Buzz Mando
I tried every LAME installer including the one mentioned at ktunes. None worked.
I made sure it was installed in the proper library file, too.
I downloaded the LAME to iTunes converter, but - in the end - I just loaded it as a AIFF file into iTunes and converted it to MP3 in iTunes.
But thanks for the help!
gearboy
Post by gearboy »
Buzz Mando wrote: I downloaded the LAME to iTunes converter, but - in the end - I just loaded it as a AIFF file into iTunes and converted it to MP3 in iTunes.
I'm telling you, use the LAME iTunes program. You'll be amazed at how much better it sounds. Seriously.
Jeff
kassonica
Post by kassonica »
+1 to that.
It is the only mp3 converter i will touch.
The itunes lame converter is easy to use, i'd be doing it.
nickysnd
Post by nickysnd »
gearboy wrote:Though I love Audio Hijack Pro, the L.A.M.E MP3 converter is the best that I have heard. Do yourself a favor. Don't export from DP as MP3. Just don't. Export in a "full-resolution" format, and then take it down to MP3. We're talking like 2 extra minutes here.
Use this:
Jeff
Thanks! I did that, and I have two questions:
- I don't seem to find the thing you call "L.A.M.E. import" playlist. iTunes encodes it as MP3 and then the new MP3 file appears in the default music playlist.
- How do I know that iTunes doesn't do its standard MP3 encoding?
Mac mini Apple M1 ♦ 8GB RAM ♦ MacOS 14.4.1 ♦ Focusrite Scarlett Solo ♦ DP 11.31
Buzz Mando wrote:I tried every LAME installer including the one mentioned at ktunes. None worked.
Have you repaired permissions? I'd try that one in my link above, again, but repair permissions before and afterward. I don't know if that would fix it, but I can tell; you that the installer in that link has worked for me on at least 4 different Macs ranging from G4 Powerbook to Intel MacPro, and I've used it at least a dozen times, and in every version of DP since LAME was enabled in it. It always worked, and I currently use LAME when bouncing to mp3 from DP. I do that nearly every day, and it works every time. You've got a problem with your system, and it may be permissions that are preventing the install or the compiling or something.
Try repairing permissions and see if it makes any difference.
zed
Post by zed »
Shooshie wrote:Have you repaired permissions? I'd try that one in my link above, again, but repair permissions before and afterward. I don't know if that would fix it...
Ha!
I'm surprised to see you giving this advice, dear Shooshie, after the thread you started last month. I thought your deduction was that in almost all cases repairing permission didn't do much of anything, and that it was a "zap the PRAM" diversion tactic for OSX. :shock:
Of course, repairing permissions won't hurt... but don't get too hopeful. :-)
Ha!
It's advised with a certain reservation, but I have to say that his system presents a challenge. It's obviously something in his system gone wrong, and it's not allowing the system either to see or to install LAME. It really does sound like a permissions problem. We'll see...
gearboy
Post by gearboy »
nickysnd wrote: Thanks! I did that, and I have two questions:
You aren't doing the conversion in iTunes. You launch the iTunes-LAME program. You simply highlight a playlist in iTunes (possibly a CD, haven't tried this yet), then go back to the iTunes-Lame and click import on that program (after setting it up in preferences in iTunes LAME). It does indeed import back into a "LAME Import" playlist (maybe I have it set in preferences for this). I just did it, and it works fine. Remember, you are not clicking import in iTunes. You simply drop AIFF or WAV into a playlist that you create in iTunes. Then, making sure that you have that iTunes playlist highlighted, click import on iTunes LAME.
Jeff
David Polich
Post by David Polich »
Audacity is an alternative. I've had great results with it. Load a .wav or .aif file into it and export as mp3, and you can vary the resolution of the mp3 as well (in Audacity's preferences). It doesn't need the L.A.M.E. convertor or anything else that is L.A.M.E. (sorry, I couldn't resist).
http://audacity.sourceforge.net/
