5.13 Upgrade
- Dubstylie514
5.13 Upgrade
I downloaded the upgrade but it wont let me open it... it says that I have insufficient access privileges.... I own DP5... do I have to have the disk in while I install 5.13?
Intel Imac, DP 7.22, Motu 828 Firewire, Aphex 230, MIDI Express XT, Rode NT2-A Mic, Proteus PK-6 Keyboard, KRK Rokit 8's
You shouldn't need the disc if you have a legit version of 5 installed. What it sounds like is the permissions are messed up either on the installer or the DP 5.13 app file. I wasn't sure at what stage you got to. You could run Disk Utility and repair permissions or alternately, do a "Get Info" on the file that refuses to open, and check the permissions and change them to the right setting to allow you to run it.
This problem happened to one of our esteemed members earlier in the year:
http://www.motunation.com/forum/viewtop ... loody+hell
Geoff!!! How did you fix it?
828x MacOS 14.7.6 M1 Studio Max 1TB 64G DP11.34
- Dubstylie514
