Where is ./user/lib ????
Well hell... I need to install something on my Mac, and I'm not a Unix geek and can't figure out how the heck I'm supposed to install a file to:
./user/lib
Is that under my user director and in the Library or do I have to run the terminal to do this??? I'm not good with OSX obviously.
Dave Bourke
Post by Dave Bourke »
It's an invisible folder, James. But you can make it accessible in a Finder window by hitting Shift-Command-G or choosing "Go To Folder..." in the Finder's "Go" menu. Then type the following and hit Return:
/usr/lib/
Kind regards.
Dave Bourke
– ideation –
Mac Pro Quad Xeon 2.66 GHz, 5 Gb, OS X 10.5.8, iMac 24" 2.4 GHz Intel Core Duo, OS X 10.6.2, Mac G4 dual 800 MHz Quicksilver, DP 7.11, PCIe-424/24i, UAD-2 Quad/UAD-1e, PowerCore Firewire.
Re: Where is ./user/lib ????
Careful James. Installing something in an invisible folder can be trouble. Are you SURE this is from a reliable source (like Frodo or Shooshie?)
I wouldn't install anything Monkey Man sent you...
Yeah... I took care of it. I had to use the Terminal app. I tried the GoTo folder thing and it did nothing. Maybe as a user I don't have enough access permissions or something.
James Steele wrote:Yeah... I took care of it. I had to use the Terminal app. I tried the GoTo folder thing and it did nothing. Maybe as a user I don't have enough access permissions or something.
You should have all access to your own computer. Apple discussions can be helpful at times. I assume you use that on occasion?
