unwanted MIDI filtering
lloydcole
Post by lloydcole »
I am new to DP, so forgive me if this is something obvious.. I have scoured the manual to no avail.
I have a problem in DP 4.5, using MOTU MIDI interface. I have 2 controller keyboards, both are transmitting controller 1 from the mod wheel. When I'm using Live, or V-synths in standalone mode both work fine, mod wheel talks to synths. But in DP controller A is getting mod wheel to VI's, controller B is not. Is it possible to have different MIDI input filtering for different devices?? If I have set this up, it is indavertant.
Any ideas??
Tim
Re: unwanted MIDI filtering
Post by Tim »
Depending on which interface you have - some can filter data at the input and output, controlled via the Clockworks app. I don't know why it would work with one seq app and not another though, since the filtering is in the interface and not the sequencer.
I wonder what happens if the MIDI cables from the controllers are swapped (on one end).
<small>[ April 04, 2005, 06:17 PM: Message edited by: Tim ]</small>
lloydcole
Post by lloydcole »
It was a corrupted (I guess) file called Filter Definitions in the DP preferences. Removed file and all works. Not encouraging, though
