Compressor Help!
mortvillefugitive
Compressor Help!
Post by mortvillefugitive »
I just picked up a Toft Audio DC-2 dual channel compressor, hoping to use it on kick and snare. I know how to use a compressor, or I thought I did:-) but I'm having a bit of trouble with this one.
I have the makeup gain dimed, because otherwise, I don't get a hot enough signal to disk. If I try to get more gain on the front end, it gets really flabby sounding, like it's clipping internally. If I do normal gain-staging, I get an incredibly quiet wave-form. The more I push the front end gain, whether it's on the compressor or on the mic-pre, the flabbier it gets.
Signal chain: 57 - SSL Alpha VHD - Toft. I had my attack and release set the way I normally set them, but I did try them with some extreme settings just to make sure it wasn't that. Any suggestions?
Also, if I return this, where can I go in the 1000 range that will be good for snare and kick? I read some other advice for compressors in this range, but it was more for vocals and I probably want FET to get a quick enough attack and release.
Logic 8, Dual 1.8GHz G5, 2GB RAM, 2X UAD1, AutoTune 4, 896HD and OctoPre, MIDI Express 128
splatterbass
Post by splatterbass »
for kick i go old school, D112 and distort the signal through my mixer ( eq out unwanted frequencies ) ala judas priest, deep purple ( old school, trick i picked up years ago ) do it live as well if i am dealing with a flabby kick sound with no tone. really negates the need for a compressor. unless the drummer has feather foot.
gtrnstuff
Post by gtrnstuff »
I have no level trouble with my Distressor or even my ART VLA. An older Joe Meek VC-1 does what you describe, just not enough output drive to get my converters working.
Mac Mini M2
16G RAM
DP 11
OS 14.7
Apogee Rosetta clock source toslink to 828x-- if it works with the new M2 Mac
