Amplitube 2
pandrews
Amplitube 2
Post by pandrews »
I'm having a problem trying to control the wah-wah pedal in my Amplitube 2 plugin setup.
Since Amplitube 2 is an insert for an audio track, it does not accept MIDI data. If I want to control the wah-wah pedal, I have to automate the insert, choosing the wah-wah parameter, then record my mouse movement.
I asked IK USA (makers of Amplitube) how I could use a keyboard to control the parameters via MIDI. They said that there were no CC# to control the plugin and that DP should be able to assign the controller to the automation
parameter.
So, how can I assign the controls on my keyboard to a parameter?
Thanks.
newrigel
Post by newrigel »
Is it that you can have more control with the KB controller or that you can't just put Amplitube in record mode and move the pedal with the mouse?
You can then go in and edit the data to your liking...
pandrews
Post by pandrews »
Exactly.
I want to feel the performance, not edit it.
newrigel wrote:Is it that you can have more control with the KB controller or that you can't just put Amplitube in record mode and move the pedal with the mouse?
Dwetmaster
Post by Dwetmaster »
Use A custom console to assign your expression pedal to it
pandrews
Post by pandrews »
Dwetmaster wrote:Use A custom console to assign your expression pedal to it
I couldn't assign the slider in my custom console to the wah-wah parameter. I only had volume and pan options for the track.
Dwetmaster
Does Amplitube support MIDI CC?
Dwetmaster
Sorry I didn't re-read your post Never mind my last post.
