Forward-Reverse with Rex Files or in LoopLab??
needlz1906
Post by needlz1906 »
Is there a forward-reverse function in MachFive 2?...I've imported a rex file and I want to have one of the "slices" to play from the beginning to the end, and then from the end back to the begining and so on.....Anyone know how to do that? Phatmatik Pro(doesn't work in Pro Tools on an Intel Mac) and my Kurzweil can do it...as well as some Roland samplers. It's helpfull in some cases for me...Please Respond!
loderunner
Re: Forward-Reverse with Rex Files or in LoopLab??
Post by loderunner »
needlz1906 wrote:I want to have one of the "slices" to play from the beginning to the end, and then from the end back to the begining and so on.....
Do you want the sample to loop-play your slice, back and forth ? Or do you just want it to play back and forth once then keep on playing ?
The first is not possible in slice mode. However you can export your loop with the slice mode modifications (tempo, envelope, etc.) as a new sound file, re-open it, set the loop points on the given slice and set the loop type as "alternate".
The easiest way to achieve the second is to copy your slice, paste it at the end of the selected slice and reverse the paste audio (using right-click or cmd-R).
Hope this answers.
edit: you can't copy/paste in slice mode... you'll have to switch back to stretch or sample. but you can do that after you've selected the slice[/b]
carrythebanner
Post by carrythebanner »
When not in LoopLab, you can use the "Alternate" loop type (set in the Sample Info pane). You can create a "regular" preset from loops by dragging the Convert button in LoopLab to a part in the Parts List (make sure to Save Presets And Samples with this new preset!).
needlz1906
I just want MachFive to loop-play one or more REX slices, back and forth while I'm holding that particular note down..In Phatmatik Pro you could click on a slice and there was a lil option for you to choose if you wanted that slice to play forward, reverse, or forward-reverse. The forward-reverse function was helpful if a slice was a lil too short. It kinda lengthened the slice in a way. It also stopped samples from sounding choppy if I slowed the tempo down...There was also a button for "one shot" which was also helpful for what i do. I'm a HipHop producer using a MPC 4000 as my sequencer triggering MachFive in ProTools BTW..If you go to page 21 of this manual in the link below it'll explain exactly what I'm hoping MachFive can do since this is really what I would be using it for..Please Respond!
http://www.izotope.com/support/help/pha ... l_v1_0.pdf
[/url]
Notaboo
reverse a slice
Post by Notaboo »
You can easily reverse a slice in looplab : select a the slice you want, do a right-click with your mouse and you will open the waveform editing tool, then you will be able to apply any process including reverse, but also normalise and any DSP. Don't forget that there is also unlimited undo, so you can do a lot of crazy experimentations. I don't know any other software doing that.
Notaboo
Post by Notaboo »
Also you can play with the "slice extension" and "extension time" in the big looplab window, this will extend the slice to fill the gap when you down the tempo.
loderunner
There is no way to loop a slice in M52.
But...
This might come close to what you're looking for. Don't forget to de-activate the "auto" extension button.
carrythebanner
Editing loop slices
needlz1906 wrote:If you go to page 21 of this manual in the link below it'll explain exactly what I'm hoping MachFive can do since this is really what I would be using it for..Please Respond!
MachFive 2 can definitely do that stuff, but you do have to convert the sliced loop into a "regular" preset (and save these new samples). Maybe they'll merge these two worlds in the future, but for now there is a workable (if not preferable) approach.
needlz1906
The "slice extension" and "extension time" in Looplab seems like it'll do what I need. I just used the forward-reverse to extend some slices so it wouldn't sound choppy.....Sounds awesome. Going to go order it now..Thanks guys!
