using Dp with a slave PT LE
claudio_61
Post by claudio_61 »
Hi,
I use Dp to write MIDI, and for various VI I use another computer.
I would use PT Le to play some VI and send MIDI data via MIDI Over lan to Pt from DP in another computer. I do the same using DP and Live (in the second machine) and it worls well. I would use some Xpand sound, and so I decided to interface PT to play Xpand, Kontakt etc. Pt didn't recognize the signal of the various MIDI channel that I've created. In MIDI input window it see the MOL ports, but it do not play the respective MIDI channel assigneds. I've also disabled the thru option but nothing. PT recognize the syncronization, MIDI machine etc, but cannot play the various intruments from external imput. Have someone try this configuration?
claudio_61
...I have set in record mode the various track and all run. If coud be useful for someone.
ciao
