Okay, been there. Done that-- didn't work.If you are in OSX, your disc may mount to your desktop. If so, simply launch UVI-Extract and select your disc from the Finder column. If your disc does not mount, Mac OS will prompt you either to "Eject" the CD or to "Ignore" the CD. Select "Ignore" and then launch UVI-Extract. In the "Disc" pull down menu, select, "Search for Sampler Discs."
This is the Peter Erskine Living Drums Sampler CD containing loops and invidudal hits, etc., all in AIF. I select 'AIF' from the UVI-Extract buttons across the top, and all my HDs plus the Erskine CD appear in the menu-- but there's a note across the top of the UVI-E window that says "no sampler disc found".
I don't get it. It's been a rough week.
Thoughts?
