ULTRALITE FIRMWARE 1.15
MOTU has released a new update for the firmware of the UltraLite which is recommended for all UltraLite users.
This can be found at www.motu.com on the Downloads page under the Firewire Software link.
Hopefully this should fix the 1.10 volume jumping issues!
first let me note that i did not ever try the 1.1.0 UltraLite firmware update.
that said - 1.1.5 update is "so far, so good"
i updated on Mar. 9
- ran the update program
- successfully completed firmware update
- powercycled UltraLite, shows 1.1.5 system
- loaded small project in Live 6.0.5 (6 software instruments tracks with various fx plugins on each track)
- it has been playing looped clips for about 45 minutes now, no problems i can hear
- i've adjusted the Main Volume from time to time, from all the way down to all up and back again - no problems that i can hear
my system: MacBookPro 2.33 C2D 17", OSX10.4.8, Audio Desk 2, Live 6.0.5, audio out of Main Outputs from UltraLite
also, i realized that i had not yet installed the MOTU Audio 1.4.3 yet, so i installed that, loaded the same project in Live - worked fine. adjusted volume up and down, no probs. i also plugged my headphones into the main analog outs of UltraLite to listen for any low-level clicks or pops - i heard only the music, and when playback was stopped, heard only silence. also played iTunes throught the UltraLite, worked fine.
i updated on Mar. 9
good news so far...
has anyone who DID try the 1.10 update (and had the random volume problems) tried the new update yet? please post if you've updated to 1.15 and let us know...
I think most of us who experienced the previous problem are hesitant to try again!
I may just do it, as I can easily backgrade again if all goes south again...
maybe this weekend...
peace,
tribalogical
peace,
tribalogical
Hello!
yes i installed the firmware 1.15 - and now my ultralite do nothing!
only on display is standing: "CPU Not Valid" and then it switch to "Firmware Upgrade (Loader v1.00)"
i send an email to motu tech. and told them my problems but i got no email back!
i try to install the firmware again and again but still not work!!!
i downloaded the 1.10 firmware(from web not motu) but its also the same sh*t!!
what can i do now????
i also had problems with firewire before: ultralite always crashes when i was playing music in iTunes or when i was workin in cubase!!!(i have an Intel-Imac and i heard there are firewire problems with them - is it true, do have somebody of u problems/crashes with Intel-macs OSX 10.4.8?
greets
greets
Ultralite&IntelMac
I had some serious problems with my Imac (2.16 GHz Intel coere 2 duo) and Ultralite. Bad static noises and sudden program errors. Yesterday I installed the updated (Date: 2007/02/14) MOTU Universal Audio Install and the 1.1.5 Firmware. It seems to work perfectly now... so far..
H.L
Firmware
I just updated my firmware to 1.1.5 and it has fried my Ultralite. It turns on gets as far as changing sample rate then turns off. It will turn back on with a blank screen then it wont turn off. I was working fine before. Now MOTU want me to pay $80 to send it back to them when it was their upgrade that fried it... Anybody have any ideas, I have re installed the update 3 times now and it takes it succesfully but then doesnt work.
- alansende
Installed it and everything working fine, just like with the previous firmware!
Not the same story when upgrading to OSX 10.4.9: Guitar Rig 2 doesn't work anymore. Avoid 10.4.9 if possible! There's a change on the AU system and some plugs doesn't run.
www.cromomusica.com - DP 11 - Macbook Pro M2 Max 96GB Ram 2TB - Focal Trio 6BE - Avalon 747 - Universal Audio - Audient ASP800 - TC Clarity M - NI Komplete Kontrol S61 MKII - Kemper Profiler - Fender Rhodes MKI 1977 - Moog Slim Phatty - Moog Subsequent 37 - Prophet Rev 2 - DSI Mono Evolver - Fender Am Std Tele - Fender Am Pro Strat - D'Angelico Deluxe Bedford P90 - Ibanez JSM10 - Fender P Bass - Fender Mustang Vintera - Beaudoux PA1 - Taylor GS Mini - Zaor, Mixingtable & Raventos Design
1.1.5 Upgrade Fails on Mac Pro
I can't upgrade from 1.0 to 1.15 on my Ultralite from my Mac Pro (4GB Intel OS X 10.4). I place the Ultralite in firmware-upgrade mode. I start the OS X "UltraLite Uploader 1.15.app." I get the window "Press button below to update..." I press the Update Firmware button. Nothing happens. The application just terminates. The Ultralight display just sits there in Firmware Upgrade mode. Any ideas?
