Soft Sampler Comparison
Hello,
I am trying to compare the 3 major soft samplers. Mach Five, Reason 3, or Kontakt. I use Ableton Live and DP5.11. I'm running a G4 Powerbook 1.67 processor and 2 gigs of RAM. I have Reason 3 and am not all that impressed when using it within other programs. It is a cpu hog in Live, not so much in DP5.11. Does anyone one have any experience with comparing these and how well they work in a laptop situation?
Thanks.
Thanks.
Re: Soft Sampler Comparison
My opinion:cleanroom wrote:...I'm running a G4 Powerbook 1.67 processor and 2 gigs of RAM. I have Reason 3 and am not all that impressed when using it within other programs. It is a cpu hog in Live, not so much in DP5.11
* Reason's sampler is in a different class than Mach5 or Kontakt. NN-XT is a small section of Reason and its features do not stand any comparision with Kontakt.
* Mach5 is not an option either because it seems that Motu has stopped the development of Mach5. To invest to a piece of software that hasn't received any updates for a long time is not a good idea.
* G4 laptop is too slow for modern sampler software anyway, you should seriously consider MacBook (Pro) with maximized RAM.
All that said there is only one option left: Kontakt 2. Yes, it is buggy. Indeed it is. But I see no other choices for my MBP.
+372 56222285
Agreed.papageno wrote:* Reason's sampler is in a different class than Mach5 or Kontakt. NN-XT is a small section of Reason and its features do not stand any comparision with Kontakt.
Stopped development?papageno wrote:* Mach5 is not an option either because it seems that Motu has stopped the development of Mach5. To invest to a piece of software that hasn't received any updates for a long time is not a good idea.
If they had, they'd have told us.
I believe the reason they haven't said anything, is 'cause they still are.
Samplers require better HD performance, but CPU demands are way down from softsynths, generally speaking.papageno wrote:* G4 laptop is too slow for modern sampler software anyway, you should seriously consider MacBook (Pro) with maximized RAM.
I'd surmise that buggy software requires constant updates by definition.papageno wrote:All that said there is only one option left: Kontakt 2. Yes, it is buggy. Indeed it is. But I see no other choices for my MBP.
Mach V is functioning and stable; there's just no Intel or UB version yet...
Korg Legacy in its various flavours hasn't required much updating, 'cause it's apparently stable.
Just playin the Gods of MOTU advocate, pappy.
The only fact here I'd like to point out is: October 17, 2005. The date of release of Mach5 1.2.3 update.monkey man wrote:Stopped development?
Soon 1 year and 5 months of no updates to a piece of software that is being actively developed.
+372 56222285
- daniel.sneed
I must add some :
I've created patchs from sampled materials, from instruments or objects, track, edit, dynamic and eq in DP, then import them in Reason 3 sampler (N19 or NN-XT).
Very easy and CPU efficient IMHO. I've had much success with it.
dAn Shakin' all over!
Even as a tiny-tot, I knew to wait until told otherwise.papageno wrote:The only fact here I'd like to point out is: October 17, 2005. The date of release of Mach5 1.2.3 update.monkey man wrote:Stopped development?
Hang, even some dogs will wait on-the-spot for days out of respect for their "owners", 'cause experience has taught them said owners deliver.
MOTU delivers, and until I'm told otherwise, I'll assume it's in the works.
Don't you think they'd 'fess up when pressed for updates on the progress of the plug if it were dead?
No, they wouldn't lie or avoid telling the truth just to protect some measly Mach V v1.2.3 update.
I think they're smart enough to know this wouldn't be good for business!
Being smart, they'd also be working pretty hard at it, so fingers crossed it appears soon.
Take heart, papageno; these guys will deliver.
When they do, it won't just be impatient Unicorns who'll be gobsmacked.
Totally off topic here, but speaks to the stability issue: My first piece of MOTU hardware was the MTP II. (Still works!!!) The software utility, MTP II Console was probably coded for System 7.5.3. but functioned flawlessly through System 9.2.2 (in a dual boot system). The shoe is still on the other foot.monkey man wrote:I'd surmise that buggy software requires constant updates by definition.papageno wrote:All that said there is only one option left: Kontakt 2. Yes, it is buggy. Indeed it is. But I see no other choices for my MBP.
2017 2.9 GHz MPB/1TB ssd; loaded 2012 i7 quadcore Mini, OS 10.15.5
DP 10.11, Logic 10.5.1, Silverface Apollo Quad/TB, K12UC, Falcon, Integra 7, MIDI guitars etc.
My how time flies when you're using Kontakt!papageno wrote: The only fact here I'd like to point out is: October 17, 2005. The date of release of Mach5 1.2.3 update.
Talk about an eye-opener...Frodo wrote:My how time flies when you're using Kontakt!
This is beginning to feel like that Twilight Zone episode where the officer, the ballerina, the clown and others are standing on top of each other's shoulders in an attempt to climb out of their void, to reach the outside world. We see them reach the top and fall into the unknown...
A child sees the "dolls" in the snow and puts them back into the Salvation Army Toy Donation barrel... (Twilight Zone theme music plays....)
(In Rod Sterling's voice) At the moment, I'm still using a juiced-up G4. But when I acquire an Intel Mac...I'm gonna be hoping...that Mach 5 v2 is gonna be there... in the Twilight Zone (Theme music plays)
Ha! I like that.flashgerkin wrote:(In Rod Sterling's voice) At the moment, I'm still using a juiced-up G4. But when I acquire an Intel Mac...I'm gonna be hoping...that Mach 5 v2 is gonna be there... in the Twilight Zone (Theme music plays)
I sure hope it's a waiting in the ether.
I have both Mach5 & Kontakt. I ended up using Kontakt for live use as it is, to my knowledge, the only software sampler with a "latch" function. Had I not needed that for live use I would have stayed using Mach5.
Both are good samplers but, despite its somewhat less appealing user interface, I'm tending to use Kontakt more these days. This may have more to do with the fact that I have an extensive library of other NI hosted virtual instruments, all of which are compatible with Kontakt.
I really like the UVI sample import option on Mach5 and the user interface is quite nice.
As for a Macbook Pro being the only option, I'd have to disagree. I've used Kontakt flawlessly in a live situation on a PowerBook G4 1.67 1GbRAM (MOTU Traveler interface). As long as you don't go mad with lots of sustained notes it works fine.
Personally, I feel your choice is between Mach5 & Kontakt. Try them both and see how you get on.......
