Anyone using Firewire 800?
Tim
Post by Tim »
I'm about to put together a couple of removable drive bays, and wonder if I should move up to 800 from 400.
Does FW 800 work well, or more importantly, better with DP?
laurence
Re: Anyone using Firewire 800?
Post by laurence »
working great here with a DP 1.25 G4 and two Lacie Drives chained to each other on the FW800 Bus... very fast... Not sure about G5's... can anyone pitch in with FW800 on G5's ? I've heard it's not so good.
DP 7.12 ~ G5 dual 2.3 / Mac Pro Quad 3/Genelec ~ ProTools HD 7.4 / 8 with 96 i/o's / MOTU 2408 Mk 3 + 1224
greymantle
Post by greymantle »
Using LaCie FW 800 on G4 Dual and G5 single processor, for music and DVD productions.
No worries here.
wonder
Post by wonder »
anyone use an external FW for streaming VI's?
Aramis
Post by Aramis »
I have been using LaCie Big disk extreme for video and audio on my G5 with no problem ...
Very good drive ....
Aramis
iMac 2012 27 ' 3.2 ghz 32 gigs ram OSX 10.9.4 DigitalPerformer 8.7 , MOTU Track 16, MOTU MachFive3.2, Ethno and BPM , Komplete 9, OmniSphere , Trilian and Stylus RMX , Axon mkII and Godin LG .
cleantone
Post by cleantone »
Can you use MOTU hardware with Firewire 800? Could you use say a couple/few MOTU896's for tracking and or mixing through the MOTU units? I assume it would be a great benefit if you can. I assumed that the hardware does not work through the new FW800.
Anyone?
tim57var
Post by tim57var »
I'm using a laCie Firewire 800 for Streaming VI's. i have Mach5 and Ivory etc on it. Seems pretty good, although Ivory has a little trouble keeping up if I'm banging some big voicings fast (like in latin/jazz music). Maybe I need some more RAM?
MacPro 8 core/DP 5.12/Mach5v2/HD192/24io/(2)2408 Mk3/(2)MTP AV/UAD-1/Powercore/Spectrasonics/NI Komplete/BFD/Ivory/Arturia/Plugsound Pro/Dimension Pro/Nord Stage88/Gigastudio/V-Stack/MacBook Pro
Tim
Post by Tim »
I wonder if track count and/or performance is better with FW 800.....
I imagine performance would be better with a FW 400 audio interface with the FW800 drive being on a seperate bus.
