Crashing at about Bar 10...
Hey All,
Its been a while but DP 4.61 has been quite steady for me for a long time and now for no reason its crapping itself in a certain project. The project was running ok on my laptop a PB1.67 and now on the Dual 1.25 with 2GB Ram its falling over. I noticed it yesterday when I went to recording in through my 2408MkIII it just wouldn't receive any audio signal no matter how I routed it. So I've downloaded the latest PCI424 update, have repaired permissions, trashed preferences, updated everything I can and its still crashing it. The project is Running Korg Legacy, 2 Instances of Batter V2, and Reaon Rewired, I've also downloaded the latest Rewire Update, can anyone shed any light? Much thanks....
8-Core Mac Pro, 10Gg RAM, PB1.67, DP 6.03, UAD-2 Solo, Battery 3, Mach 5 V2, Korg MS2000R, Roland JX-3P, Korg Polysix, Allen & Heath Mixwizard 2+, TL Audio FAT Compressor, Universal Audio Twin Finity, Micro express, 2408 MkIII w/Blacklion Mod's, Yorkville YS-PM1 monitors, Guitars, Bass....
Hey, Adam.
Have you tried copying the project?
How about loading its chunks into a new template?
Failing the aforementioned, I'd try rebuilding/loading (DP 5.x-> only) the project's audio bundles.
Should you still be in strife, I'd re-install again (sorry), but forego all unnecessary 3rd party installations.
Should this bear no fruit, I'd go buy a banana; they're cheap in Hellbin at the moment.
Hope there's something for you here. If not, the Geeksters ought to arrive shortly.
Just don't let Frodo talk you into buying any more RAM without drilling him first.
More Info
Thanks for that Monkey Man. Yeah I copied the sequence into a cliping window, then rebuilt the project again from the ground up, fortunately it was mainly MIDI data at that stage. Then as I was going through loading the VIs one by one I noticed something. I'm running two instances of Battery V2.1.5 and the problem is with one of the kits, I'm running the Reggae kit and the Hip Hop kit and everytime I try and run the Hip Hop kit it just falls over. But with just the Reggae kit up its runs fine. I've sent a support request off to Native Instruments so we'll see what they say. Most of the drum programming is with this kit so I loathe to change it at this point...
Hey, at least you've still got the project, Adam, or should I call you "man"?
Great news; I'm happy for ya.
Enjoy the warm weather.
Nicky
Nicky
- Dwetmaster
While I'm freezing myself like crazy Up North...monkey man wrote:Enjoy the warm weather.
- Dwetmaster
We've been peaking at -30C lately.
sorry for the Thread hijack...
Speaking of freezing--
I wonder if Adam is at the point in his projects where he could freeze up some tracks?
I understand the love for DP 4.61, but DP 5.x has Work Quanta and Max Work Percent which can help divert additional resources from other functions to MAS. Giving one or the other of these a nudge has really come in handy.
But that it worked fine on the PB and not on the tower-- hmmm...
Two things--
1. try disabling the PCI 424 and run the project using Built-In Audio
2. try uninstalling and reinstalling DP, perhaps under a new user name. Anything related to DP located in your user Library can be moved to your root Library
Two things--
They promise so much, but can they deliver?jarok wrote:Hi
Same here. It is 10 degrees celsius below right now.
For tomorrow they promise 17 below.![]()
jarok
For your sake Jari, I hope not.
Don't fret, Dwet; just try not to get wet.Dwetmaster wrote:We've been peaking at -30C lately.
Poor bugger, I feel for ya, and it's mighty chilly.
- Eleventh Hour Sound
This may have already been covered, but I would also check to see what happens @ bar 10 right before the crash. Sometimes an event like a plug in kicking in, too much automation, AutoTune 4.39 MAS... etc can cause it....
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars
