What happened "view selection in sequence editor"
terbano
Post by terbano »
A handful of versions past, when I would select a specific region over several audio tracks in the tracks window, then execute the "view selection in sequence editor" command, the region would open in the sequence editor ZOMMED ALL THE WAY IN BOTH HORIZONTALLY AND VERTICALLY, and I could go right into fine soundbyte editing. Now, with the same command, the region opens zoomed in fully horizontally, but zoomed out vertically...EVEN IF IT LEAVES A TON OF BLANK VERTICAL SPACE IN THE SEQUENCE EDITOR WINDOW. I then have to execute vertical zoom commands to get it to fill the window. In addition, Track Folders are included in the sequence editor, taking up tons of real estate. This is a real killer - fine editing of soundbytes used to be a snap...now I am key-stroking away to get a nice, full horizontal and vertical zoom to fill the window and edit away.
This definitely needs to be addressed...
Tim
Re: What happened "view selection in sequence editor&am
Post by Tim »
I get that too, but not every time.
I think it's when I have many folders.
