To 896HD or Not To 896HD?
- Dwetmaster
I already have one and I'm looking into expanding my number of input. I read a lot of post about user having problem to sync 2 896HD together. they usually end up buying a pair of RME.
I like my 896 but should I just get a 8pre and connect it adat? or is it worth it to get another 896. Are the pres of the 896 are respected at least a bit in the professionnal business or should get outboard pres?
- Dwetmaster
bump...
If you are happy with the 896HD pres then so be it.
I run a shop with lots of great outboard and have a dual 896HD rig for remote stuff and although i don't love the pres as much as my APIs, Neves etc. they work fine for many applications.
Except for initial setup, i've never had a problem getting the 896HDs together.
The only trick is that you need to link them via AES if you want to monitor through cue mix.
As per the 8pre is concerned, i hate light pipe and everything it involves.
Fibes
"You can like it, or not like it."
DP 7.24, 12 Core 2.66, Reason, Live, UAD-2 full meal deal, Sonalksis 315 & 517, DUY Everpack, Altiverb 6, Apptrigga, Autotune 5, OHM Force Experience, Audio Damage Dishord/Adverb/Dubstation, PSP full meal deal, Camelphat/Space, Wave Arts Power pack and many more.
- Dwetmaster
Thanks for the reply but may I ask a bit of precision regarding your hatred of lightpipe?Fibes wrote:As per the 8pre is concerned, i hate light pipe and everything it involves.
Anyone else for or against 8pre or a second 896HD?
Hi, I have a 896HD too, and I am thinking on expanding to 16 analong inputs buy using one of those 1u pieces that provides 8 amps with adat out, and i was thinkin of the focusrite octopre, or the mackie onyx r800. Both units have realy good amps, but i would do more research on de converters. Anyway, thats another way of expandig inputs with the 896HD.
Um, many years using it and dealing with pops, clicks, drop outs and all manner of clocking issues.Dwetmaster wrote:Thanks for the reply but may I ask a bit of precision regarding your hatred of lightpipe?Fibes wrote:As per the 8pre is concerned, i hate light pipe and everything it involves.
That and the limited bandwidth, limited durabilty and distance for the cables...
I guess you just had to be there.
Fibes
896HD AES Link
Fibes...when you link the 896hd via aes do you still use the firewire hub link on the 896hd ?"The only trick is that you need to link them via AES if you want to monitor through cue mix."
What configuration are you using to link dual 896hd via aes (hardware/software settings) ...
I would like to try it and see what results i get....
If you would be so kind as to give me an idea of how you are set up i would greatly appreciate it.
Currently i have dual 896hd synced via the firewire at the back of the 896hd itself. Sync is pretty solid but it does drop out from time to time for no apparent reason...
motu drivers 3.6.7.3..win xp pro sp1...sonar 6 producer edition
Asus PC-DL Deluxe Server Motherboard
Dual Intel Xeon 3.2 Ghz 2Mb L3 Cache 533 Fsb
Intel 875 Chipset, 4 Gb Ram, 256 Mb Agp 8X Video
Belkin Firewire Pci
Maxtor Sata 7200 rpm 16 Mb Cache 250 Gb X 3
Dual Motu 896HD Firewire Interface
Presonus Digimax LT Pre-Amp
Windows Xp Pro Sp1, Sonar 6 Producer
Native Instruments Komplete 3
Belkin Firewire Pci
Re: 896HD AES Link
Check your PM.edwardb wrote:Fibes...when you link the 896hd via aes do you still use the firewire hub link on the 896hd ?"The only trick is that you need to link them via AES if you want to monitor through cue mix."
The AES link is mainly for monitoring purposes not clock.
Wordclock would be best via a good external clock.
And no, I'm not a big fan of external clocks on my PCI424 studio rig, just the firewire 896hds.
Fibes
