What is Cuemix "sequencer"?
danshouse
Post by danshouse »
I have a 424 card, a MOTU 2408mkII, and a 24i. I appear to have no documentation for Cuemix.
What the heck is the cuemix "sequencer"? My cuemix display says that, for instance, 6 faders are used in cuemix, and one fader is used in the sequencer.
What sequencer? I have no control surfaces connected - is "sequencer" a control surface function?
One of the inputs on the 2408 is routed to outs 1 & 2 on the 2408, and I can't figure out how this is happening - it is not reflected in any of the Cuemix mixes.
Even with all faders in all the possible Cuemix mixes at the bottom, this one input remains invisibly routed to my main outs! I can't turn it off, and it's driving me nuts.
Could it have something to do with this "sequencer"? I remember when I first used Cuemix (a week ago), it said 0 faders were used for the sequencer...
danshouse
Post by danshouse »
bump
Someone's got to know what this means...
At least maybe someone can direct toward some documentation for Cuemix. There's nothing about it in the docs that are installed with the 424 software, and I can't find anything on MOTU's site that mentions it.
Emusic1
Post by Emusic1 »
Hi there, Are you sure its one of the inputs and not the playback output from your sequencer that you are seeing?.
Cuemix shows the output signal from your DAW on its main output meter but does not give you an individual Fader for that signal.
Try muting the Master Fader in DP (assuming thats what DAW your are running and see if that gets rid of it) , or turn down all the Channel Faders in Cuemix to see which channel pair your'e seeing on the Master Outputs in Cuemix. Good Luck!
