Hi All.
I am currently using a Dual G4 1.0 with 1.75GB Ram and two hard drives inside. I am running DP 5 on this machine and loving, except for the darn noise it makes. (Loud Fan) I use Waves Plugins to mix with and have had an easy time with it, rarely maxing out the CPU.
I have a 1.83 MacBook Pro with 512mb RAM at this time, I did a full mix on the machine and it held up perfectly, not even close to 50% with a good amount of tracks going and about 2 plugs per channel. I am wanting to use my 828 and the MacBook as my main computer for tracking and mixing, is anyone doing this yet? Anyone having any issues with memory? If I do use the MacBook I would max the memory out and use an external drive for audio. I guess I am wanting to know if anyone is using the MacBook for heavy duty recording, editing and mixing...What is your impression?
Mixing with MacBook Pro?
- Pappy725
Well, it's not a MacBook Pro, but I use my Ti PowerBook with a 1GHz processor to record and mix with my 828mkII. Yes, max out the RAM and use an external drive. I daisy chain a FW drive thru my 828, but others have had problems with this and suggest a FW controller card for the Cardbus? slot to plug the external drive into. I record 10 channels regularly for 3-4 hour gigs.
HTH,
Stephen
HTH,
Stephen
MacBook Pro (Retina, 15-inch, Early 2013)
2.4 GHz Intel Core i7, 8GB RAM, OS High Sierra 10.13.2, DP8.07, 256GB SSD
828mkII, 8Pre, Alesis M1 Active Mk2, Ext. FW drives, Yamaha fretless bass, Kay upright bass, Wechter acoustic/electric, trombone, baritone and a proclivity for polka music. (With sufficient quantities of beer) and I play country music.
