Code: Select all
* SysEx Librarian is now a Universal application. It is 100% native on Intel and PowerPC
* The source code is now available.
* You can now change the sysex transmission speed, on a per-device or per-port basis. A few older MIDI devices may need the speed to be turned down to work consistently.
* Added a "save as .syx" feature, just like the existing "save as standard MIDI file". Now you can convert .mid to .syx!
* We now show checksums at the bottom of the sysex data in the details window, to make it easier to check if two sysex dumps are the same or different.
