Digital AES/EBU and XLR..Whats the difference?
lsdd
Post by lsdd »
Can I use an XLR mic lead as an AES/EBU Digital connection??????
It seems to work........
xxd
G5 dual 1.8, Leopard/ DP4.6.1 / 2408mk3 / Mach5| / Korg ES1/Korg Ms2000
rklegon
Post by rklegon »
AES/EBU is a stereo digital transfer protocol which uses an XLR connection/cable.
So to answer your question, yes, you're doing this right. AES/EBU uses an XLR cable/connection, just like S/PDif (another stereo digital transfer protocol) uses an RCA cable/connection.
kelldammit
Post by kelldammit »
with SPDIF, you should be sure to use 70ohm (video) RCA :)
Feed the children! Preferably to starving wild animals.
ASUS 2.5ghz i7 laptop, 32Gb RAM, win10 x64, RME Babyface, Akai MPK-61, Some Plugins, Guitars and Stuff, Lava Lamps.
lsdd
yeah
Post by lsdd »
A friend of mine said it's a special kind of XLR lead, should be gold plated, but that it's fine to use a mic lead to get out of trouble....hmmmm
Thanks everyone!!
xxd
rklegon
Post by rklegon »
kelldammit wrote:with SPDIF, you should be sure to use 70ohm (video) RCA :)
I believe it's actually a 75 ohm RCA cable. There's also optical S/PDif (TosLink) which is carried over an optical cable.
Anyway I guess you could say that S/PDif is to Consumer as AES/EBU is to Pro. (although there are some differences)
woodlakesound
Re: Digital AES/EBU and XLR..Whats the difference?
Post by woodlakesound »
lsdd wrote:Can I use an XLR mic lead as an AES/EBU Digital connection??????
xxd
Bob Katz has stated within 10 feet a top quality mic cable can be used with sample rates at 48k and under without detecting losses. Though it would still be optimal to use AES/EBU spec if ya got it.
Cory
acro
Post by acro »
Careful -- I think the spec was 110 ohms, if I remember correctly.
stephentayler
Post by stephentayler »
Yes 110 ohm for AES/EBU, 75 ohm for spdif
use the best cable and connectors you can get and keep length to a minimum.
But a mike lead will work if you are stuck.
Stephen
mhschmieder
Post by mhschmieder »
Although I no longer own any gear that supports AES/EBU, I still own one cable for that purpose, and there is a different impedance than for a standard mic cable. I had to label it so I don't make a mistake later on, as it doesn't say "AES/EBU" cable -- merely something to the effect of "high throughput mic cable" or something else a little bit indirect like that.
But I think it makes a bigger difference beyond 10' of cable length. Mine is a short patch cable, so I probably could get away with a standard XLR patch cable without data loss. I can't really run this experiment though -- the 896 is long gone and everything that I have now is S/PDIF.
