Hi !
What could be the best macpro customization( memory capacities,etc..) to create with DP, some plugs (about 5) , some virtual instruments
(about 9 ),some audio tracks (vintage synths without MIDI(4) and demo voices (6) on each session ?
I need a stable, longlasting seq run and reliable system to be "creative" and nothing else !
Thanks guys , need your expert advise to continue my trip..
Yaboss
In fact , I'd like to have a system which is bigger than my request and try to avoid problems this way. That's why I prefer a "big" computer even if my needs are not so heavy. Maybe you'll be ok with me , it's hard to limit ourselves nowadays...
Cool.
Just don't under-estimate what a G5 or a Mac Pro can do...
G5 Quad or Mac Pro 2.0 should be double what you need.
Is a 100% "grunt margin" enough for ya?
Should be, else you're just ripping yourself off.
i have a macbook, and yes, you should be easily able to do this.
for instance, even on my g4 1.67ghz w/1g ram, i was running 30+ channel (48k/24) mixes in which all audio was bounced from vi's. this is playing back off of the internal drive, no less.
how many vi's you can run at once will depend on a number of things:
1. how much horsepower does each vi draw? balance that with the polyphony, and it can seem pretty limiting. for instance, on my g4 with a heavy duty blue patch, i could barely get one instance to work without dropping out, and only as long as i only used 1 or 2 voices. so...even on a dual 2.0 intel machine, i'm seeing some limitations in that regard (though, now i can run usually about 1/2 dozen instances of blue playing 3-4 note chords). remember, you can always bounce and save the cpu.
2. how many other plugs do you already have in-line?
3. how much bussing, etc do you have going on?
4. how many channels of audio playback are going on?
as a rule, the more memory, the better. you may as well max it out to start with, you'll probably need to do so anyway eventually.
either way, i'd say the macbook should get you where you need to go.
enjoy!
kell
Feed the children! Preferably to starving wild animals. ASUS 2.5ghz i7 laptop, 32Gb RAM, win10 x64, RME Babyface, Akai MPK-61, Some Plugins, Guitars and Stuff, Lava Lamps.
kelldammit wrote:i have a macbook, and yes, you should be easily able to do this.
** About 6 Vi's , 4 plugs (as fx,eq..) for a sesssion
** never tried more than 1
** some demo voices (4-6)
