Neve 8816 Summing Mixer question
picardmyhero
Post by picardmyhero »
Question about the Neve 8816 summing mixer:
While you can add an effects box to the entire mix, it seems that the only way you can signal-process one channel is by getting the fader box, (which has direct outs) and using a channel as a return from the effects unit.(?) What do you do if you want channel one to have a delay and channel 2 to have reverb while you mix back to the daw?
Are you supposed to use digital effects and process the channels separately on the daw before they go into the nev?
