Go with Tiger, or stick with Panther?
- doctormelodious
Greetings,
After running DP 3.11 in OS 9 on my Dual 1GHz G4 QuickSilver tower for about a year, I have finally moved up to DP 4.6 (found a copy on eBay). My Dual-gig currently has Panther (10.3.9) on it. My question is, should I go ahead and grab a used copy of Tiger, or sit tight with Panther? Which will give me a smoother ride w/DP 4.6?
At some point, I'll go Intel/Leopard (when it's here), but I plan to wait for the dust to settle first.
Doc
Doc
Mac Pro 8 x 2.8GHz, 16GB, OS X 10.6.8
DP 7.24, MachFive 3.2, EZ Drummer, RealGuitar/Strat/LPC
Ivory II Italian Grand, Korg Legacy M1/PolySix
Garritan PO4/JABB3, NI FM8, Vintage Horns
UAD-2 Solo, RME FireFace 800
Mackie HR824s, various mics/keys/outboard
"What a beautiful world this will be. What a glorious time to DP!"
- giles117
I agree on your quicksilver (I Had One) Stay Panther 10.3.9 at the most. Unless Panther isnt working for you.
DP 6.02
Quad 3.0 Ghz, 8.0 GB RAM, 2 - 1TB HD, 5 - 500GB HD's (RAID)
MOTU HD192, 2408mk3, Microlite, UAD-1, UAD-2, Powercore, Lavry Blue AD/DA convertor, LA-610
Euphonix MC Control
29 years in this business and counting.....Loving every minute of it.....
Euphonix MC Control
- doctormelodious
I didn't make it clear, but the DP4.6 I won on eBay hasn't arrived yet. So I have no hands-on experience with it yet. I will put it through its paces in Panther for starters. Just thought there might be some whiz-bang advantages to Tiger that I needed to know about. If not, I'd just as soon keep things where they are.
Thanks for the replies!
DM
DM
Ah. I see.
Yeah. Give it a go in Panther. You might be quite pleased. I ran it on my Quicksilver single 867 with great success, except for certain AU and RAM limits that put a quick cap on things like Altiverb after two instances. I ran quite a bit of audio tracks with it, though-- but that was before I started adding VI's.
The 1Ghz was enough of a speed bump to make a huge difference.
Absolutely not. The new features in Tiger are royal pains in the ass to DAW users: Dashboard and Spotlight need to be hobbled or disabled, as they interfere with disk operations or hog precious RAM and compete with DP for CPU resources.doctormelodious wrote:Just thought there might be some whiz-bang advantages to Tiger that I needed to know about.
DM
My advice is don't install Tiger until the software you need won't run unless Tiger is required.
10.3.9 is lean and mean and is all the OS you need for DP. At least, that's been my experience.
DM[/quote]
10.3.9 is lean and mean and is all the OS you need for DP. At least, that's been my experience.[/quote]
Depends what kind of system you have running:
A g5 will perform better at most tasks with tiger, since it introduces true 64-bit operations into the OS. Check barefeats.com for benchmarks. Spotlight is actually quite useful for DAW users, in that it we tend to deal with huge amounts of files, (audio, fx presets, alternate mixes) and spotlight allows you to find the exact location of these things almost instantly. Besides, you tell spotlight to not search or index any drive you like, so you can have it switched off on a dedicated audio drive, but leave it turned on on your boot disk. Once it is switched off, it is OFF, hardly a "pain in the ass..." As for dashboard, it actually doesn't consume CPU cycles unless you activate it for the first time after a reboot. Then, once it is put away, the system puts the process to sleep, stores it's last settings in RAM (less than 3-4 mb if you have no widgets open) and it consumes NO cpu cylcles. This is UNIX at work here. And, if you might need those 3-4 mb of RAM, Tiger will push that bit to virtual memory.
If you have a dual g5, with over a gig of ram, i don't see any reason not to move to tiger unless there are compatibility issues w/ software. The benefits far outweigh any 'annoying' features apple may have added to this great os.
on the other hand, if you have a single g5, or an older g4, well then, things are different. i recommend dual booting at first, to ease the transition...if tiger is a bust, then no worries, back to 10.3.9...
just my 2 cents
just my 2 cents
I guess I should have mentioned that my DP computer is a d800 Quicksilver G4, and need to conserve CPU power. I'm starting to like a couple of features of Tiger on my PB, but seriously, go to the Apple web site, and look at the "200 new features" in Tiger, and prepare to yawn in disinterest. Likely, most of us will never use 190 of them. I know a lot of people love whatever the newest thing is, but I'm not impressed.
I had to install Tiger to run Avid Express Pro 4.8.x, and the Avid forum experts recommend disabling Spotlight and Dashboard. Since NLEs and DAWs share some common operating principles, I passed the info along. I didn't mean to mislead anybody.
If you plan on going to DP 5.01 or higher I'd suggest going to Tiger. Also with an eBay auction, make certain the person selling you the copy is willing to transfer the license to you for it to be legit, otherwise this means upgrading to DP 5.X won't be an option.
10.3.9 works best for my setup (G4 Digital Audio with a Sonnet 1.2Ghz) My logic board is almost the same as the Quicksilver. I would get performance spikes in DP with 10.4 even with Dashboard and Spotlight disabled on a fresh OS. And this was with a single stereo 44.1/24 track. I noticed that with 10.4 and DP running idle the Nice process was about 70% and overall processor usage actually hit 105%. With 10.3.9 there is no Nice process usage at idle and processor usage is where it should be. No more problems.
Plan on getting a new Machine with DDR RAM if you move to Tiger and/or DP 5.
You could consider adding another internal hard drive and install TIGER on the new drive and keep Panther on the other drive.
Drives are relatively inexpensive these days.
I have found that every new OS upgrade requires more RAM and CPU.
I've got both Panther and Tiger and find that Tiger is more stable and robust then Panther.
Mac OS: Mojave
Is it me or does it seem like Tiger seemed just a bit more optimized and a bit more responsive as well?midiw wrote:I've got both Panther and Tiger and find that Tiger is more stable and robust then Panther.
It feels that way on the G5's, anyway...James Steele wrote:Is it me or does it seem like Tiger seemed just a bit more optimized and a bit more responsive as well?midiw wrote:I've got both Panther and Tiger and find that Tiger is more stable and robust then Panther.
