Have an old G3, wondering about loading OSX and DP4.?
bigcitysound.com
Post by bigcitysound.com »
I have an old Blue and White G3 that is still running 3.1 on OS9.1...
I have a new G5 running OSX, and am getting a little fed up with my old 3.1 limitations... I have heard (and read here) rumors that the G3 is actually capable of happily running OSX and DP 4.? as long as you don't push the computer tooooo hard... My questions are these:
1) My G3 is stuffed full of memory, so can it be a useful (i.e. could I mix a 30 track song with several inserts) on OSX
2) If not, can it be used as a stand alone synth Box using OSX for Reason etc?
3) What are the pitfalls I need to look out for?
4) I have hesitated to make the change, since it would require stripping all of the working material off the hard drive, etc. Would it be smarter to just buy a new hard drive, install everything on the Hard Drive, and then move it into the boot position on the G3, and use my old hard drive to move the files onto the new drive?
Anyone's direction on this would be welcome... I hate to throw away perfectly good machines, and they are worth more to me than on Ebay...
-peter@bigcitysound.com
Newsles
Post by Newsles »
I have a G3 that I upgraded with a G4 board (Powrlogix), and even with that Ive been warned off installing OSX - memory, processor speed etc etc.
To be honest, Id like to go DP4 (and now 5) but Im happy at 3 - it does what I need, and works very well (and is stable) on my little Mac.
So the concensus seems to be dont bother it's not worth it - youre likely to see a fall in performance, or even worse if my reasearch into this tells me anything.
Cheers
Les
I refer the Honourable Gentleman to the anwser I gave a moment ago...G4-upgraded G3, DP2.72, Korg 1212 card, Fostex 8-channel AD/DA converter, Korg DW8000, Novation Basstation, Kork M1rEX, Vintage Keys Plus, Akai S2000, Transcendent 2000 monosynth, Presonus ACP8 8-channel comp/gate, Behringer Multicom, Zoom and Yamaha external FX and a few other bits and pieces!
crez5150
Post by crez5150 »
I really can't see that happening.... I have a G4 stuffed with RAM running DP3.11..... and its just about copes..... I am not upgrading to osx on this machine until i can afford to go for an intel system.... or until the new intel twoers become available...
When the drums stop...... it's the Bass solo!
