Please help!
I have a Yamaha DTXpress II & want to put each drum from the set on it's own track, like snare on one, kick on another ect. via MIDI.
I got drumagog pro and a midiman/uno MIDI cable. I'm able to record MIDI from my dtxpress II into DP but I can't get drumagog to play it's preset samples from the MIDI. It seems that drumagog can only be inserted into an audio track so my MIDI output track says drumagog/audio 1 (which is where I inserted drumagog) /insert E-10 (chose that out of E-1 through E-16 figuring maybe it has to do with MIDI channel 10, I don't know)
I can't get the audio 1 track to relay any any sound especialy since there is no sound to record! Don't even know if this needs to be done.
In drumagog I have the MIDI channel set on 10. MIDI in only has "internal port" to select. MIDI out has "internal port", DP input" and "apple software synth" to choose from. I guess I need to select MIDI in's "internal port"?
I've tried all options yet nothing. MIDI note is C4 but don't see why that would matter right now.
In DP when I set the output to "apple software synth 10" the MIDI plays a pretty accurate representation of what I played except the kick and snare are a stick sound.
Also what happened to my "live" mode under the advanced tab? It was there, now it's gone.
Any ideas? I'm lost.
Drumagog MIDI DP 4.6 confusion please help!
