HELP! Death Screen
Timmy S
HELP! Death Screen
Post by Timmy S »
I am in the middle of mixing a major project in DP 4.6. For the last few years of tracking and recording it has been nearly flawless. Now in the middle of mixing ( about every 15 minutes ) that macbre screen descends and hangs on a half lit screen with some forein font on it, and needs to be restarted. Also I have noticed that my mouse is intermittent and needs to be disconnected and plugged in to the usb jack to work again. I have repeaired permissions and dried disk utility to no avail. Another hardrive I have in this dual 2 Gig G5 died recently and I removed it, don't know if that's releated.
Any advice or suggestion to try would be much appreciated. I have tried many different files and it happens in all of them.
thanks,
Tim
"who ran the iron horse?"
chrispick
Post by chrispick »
Hmm, I wonder if it's a motherboard thing, given the USB problem. It definitely sounds like a hardware issue of some kind. Death screens usually mean that (with defective RAM being the most likely culprit, though perhaps not in your case).
Can you get a copy of Tech Tools and run a diagnostic? Might give you some insight.
In the meantime, do backup everything you can.
ramadev
Post by ramadev »
Hey Timmy S, check your email
from "he who named the E'sphere"
Nehalem Dual QuadCore 3.2GHz/8GB/828/MTP AV/10.6.8/DP8.0-DP7.22/Altiverb6.3.5/ChannelStrip2.2.23/T-Racks/AutoTuneEvo/GuitarRig4/Drumagog/bx_XL/FG-X,RC-Tube,VTM/EventideOmnipressor/MelodyneStudio-Cre8 3.2
MacBook Pro Intel Core 2 Duo 2.66GHz/2GB/Traveler/10.6.8/DP8.0-DP7.22/Altiverb6.3.5/ChannelStrip2.2.23/T-Racks/AutoTuneEvo/bx_XL/MelodyneStudio-Cre8 3.2
Neumann,AKG,Earthworks,Soundelux mics/ManleyVoxBox/Avalon737/Amek9098/Genelec1031As
billf
Re: HELP! Death Screen
Post by billf »
Timmy S wrote:I am in the middle of mixing a major project in DP 4.6. For the last few years of tracking and recording it has been nearly flawless. Now in the middle of mixing ( about every 15 minutes ) that macbre screen descends and hangs on a half lit screen with some forein font on it, and needs to be restarted. Also I have noticed that my mouse is intermittent and needs to be disconnected and plugged in to the usb jack to work again. I have repeaired permissions and dried disk utility to no avail. Another hardrive I have in this dual 2 Gig G5 died recently and I removed it, don't know if that's releated.
thanks,
Tim
Sounds like a kernel panic, which are often related to bad RAM (not always, but a lot on OSX which is fussy about the RAM quality).
Does it look like this?
http://docs.info.apple.com/article.html?artnum=106227
Timmy S
Post by Timmy S »
yes it looks just like that.
Thanks for the replies.
T
Timmy S
Post by Timmy S »
I have noticed that it seems to only happen in DP and not other Apps.
ramadev
Post by ramadev »
If that multi-language screen is indicative of a hardware problem and it only happens in DP, then maybe it's the A/D/A interface.
Call me at home; I'll loan you one of my interfaces if you want to test that.
You still have my number, right? (I can't find yours right now.)
Kubi
Post by Kubi »
Just FYI, kernel panics are not always caused by hardware problems, though they can be. But they can be software-related as well.
(They were for me some 18 months ago. A complete reformat and fresh install of the startup drive fixed my problems completely.)
Good luck!
