Movie audio out of sync
I recently updated to DP 4.6 and since then I've had issues with the audio from the imported movie. The audio from the movie gets out of sync. The audio is always ahead of the picture. This happens even before I've started writing any music. The movie is running from my internal hard drive. Does anyone know how to fix this? Thanks.
kristupes
Re: Movie audio out of sync
Yeah, this is a known thing.kristupes wrote:I recently updated to DP 4.6 and since then I've had issues with the audio from the imported movie. The audio from the movie gets out of sync. The audio is always ahead of the picture. This happens even before I've started writing any music. The movie is running from my internal hard drive. Does anyone know how to fix this? Thanks.
You can either:
1. Copy the audio from the movie into your sequence, then turn down the volume in the movie window. Then, just use the audio-from-sequence for listening and bouncing. It's in sync and will stay in sync throughout the process.
or...
2. Deal with the audio sync difference that occurs from using the movie window audio as playback by minimizing latency as much as possible..
I prefer the first solution. I know that some others who score long-form projects and don't like to wait for the copy-to-sequence function to do its thing prefer the second solution.
I think there's been talk of DP5 possibly correcting this sync-from-movie-window bug, but that's only hearsay really. It'd be nice.
- Mr_Clifford
Apparently they've fixed the bug with the DP 5.01 patch. Downloading it right now as I type. Will confirm.
Personally, I like putting the movie's audio on to an audio track, because then I can compress the stuffing out of it and route it to a separate channel on my monitoring mixer.
DP 9.52 Mac Pro 10.14.6 RME fireface800. Sibelius. Dorico 4
- Mr_Clifford
Hi All,
I am working on my first film scoring project and am trying to sync my score with the Video but am having a discrepancy between the imported audio from the QT movie, and the audio track from the video window itself, and like mentioned in this thread the audio in the movie window seems to be early.
The reason I ask is that I have a sync beep, and I need to know which one is correct so my audio maintains its timing with the video. I am assuming that the imported audio is correct without adjustment and the QT movie window audio is early (thats what it looks like), but I want to make sure that I should base my sync beep off the imported audio track and not move that imported track to sync with the movie window audio...
make sense?
So if I copy the sync beep from the imported audio into my sequence the timing should be all good, right?
Thanks in advance for the advice to a novice.
Jonny
PS I'm on a PB g4 1.33 with 10.4.9 and dp 4.6.1 and a presonus firebox
make sense?
Jonny
"We are the music makers, and we are the dreamers of dreams...."
- Mr_Clifford
Use the imported audio from the QT movie. Using the sequence editor you can move the cursor to the sync beep and check that the video window is on the flash (the white frame that goes with the beep). If that's the case then your whole video is synced - if you have to move it (you won't.... hopefully) make sure you set the user timestamp so that it will automatically sync up with any extra cues.jonnyfive wrote:So if I copy the sync beep from the imported audio into my sequence the timing should be all good, right?
If you have QT Pro, you can open the QT file and save a version without the audio, which saves you having to turn the volume on the video down.
if you're spitting vid out the firewire port - then read up on setting the playback offset
macpro 3 gig - 5 Gig RAM 10.6.3 Motu 2408 mk 2 Mackie HUI DP 7.21 intel imac 3 gig ram traveller OS 10.6.3
http://www.fork-media.com
