question about loops
Posted: Thu Mar 23, 2006 5:41 am
by guitarsark
how do i change the tempo of the prerecorded loops in machfive?
sorry for my ignorance, i'm pretty new at this.
Posted: Thu Mar 23, 2006 11:00 am
by guitarsark
come on now, someone must know the answer to this question.
Posted: Thu Mar 23, 2006 1:36 pm
by 3over3
sorry, without any further info (like do you mean REX loops or single samples? Are they in slices? How are you triggering?) this might sound a bit glib - you need to pitch them up or down... play with the pitch section!
Posted: Fri Mar 24, 2006 7:30 am
by guitarsark
the loops are the sample loops that shipped with my machv sounds dvd.
thanks,
Posted: Fri Mar 24, 2006 8:26 am
by thracks
guitarsark wrote:the loops are the sample loops that shipped with my machv sounds dvd.
thanks,
You can't do timestretching within Mach 5 (yet!) When (and if) version 2 ever ships you will be able to. For now you need to take the raw sample and load it into DP, do your tempo change and then export the new sample-load into Mach 5.
Posted: Fri Mar 24, 2006 1:43 pm
by 3over3
Can't you pitch them up and down to match the tempo? Am I missing something here?
Posted: Sun Mar 26, 2006 8:42 am
by thracks
3over3 wrote:Can't you pitch them up and down to match the tempo? Am I missing something here?
Then the pitch will change won't it? That is usually an undesirable result when working with rhythmic loops.
Posted: Sun Mar 26, 2006 10:59 am
by 3over3
thracks wrote:Then the pitch will change won't it? That is usually an undesirable result when working with rhythmic loops.
...only if there's a pitch reference in the loop. If they're only percussion/drums etc, there's not usually a problem. Otherwise, load the sample into your host and work out how to stretch it. In Pro Tools, for instance, you can graphically stretch the audio and make it snap to your tempo very easily.
