iMac G4 loose neck
iMac G4 loose neck
My iMac G4 flat panel's neck is loose. Any ideas where to get the tool or how to tighten it up?
If you still have apple care you might want to give them a call or visit an apple store. If it's not under applecare, you're kinda out of luck do a google search for this problem and there might be someone out there that may have a bandaid type fix, that goosneck is a very tricky mechanism spring loaded and all it you can really mess things up with the display if not careful
