FW connection clicks and pops
Astia
Post by Astia »
This morning we got a FireWire card for our new Mackie DigitalXBus200 console and I‘m having touble getting a clean signal from DP. Depending on the settings there are click either on the FW channels or on the light pipe channels.
Here is our setup:
G5 dual 2,27G w/4G ram
OSX 10.4.4, DP 4.61
Apogee BigBen as master clock
2408mkIII (3 x light pipe to DXB inputs)
fire wire cable to DXB
I searched Unicornation and found great tips once again from qo. The audio from FireWire was horrible before I changed the HBM to 4 and Work priority to low as he suggested. I tried different disk read/write & buffer size values but still some clicks appear.
I was supposed to do a proper testing before using the FW card routing for out clients but the temptation was too big and we are just starting to mix 2 bigger projects.
This problem can also be a non-DP-related but all tips are more than welcome.
Thanks in advance :)
G5 2x2.75GHz, 4G RAM, OSX 10.4.5, DP4.61, Mach5, 2408mkIII, 1296, ExpressXT, AutoTune3, Waves Renaissance, PowerCore mkII, UAD-1, 2-1176, Distressor, LA2A, TLAudio VTC, Mackie DXB200 w/3xUAD-1..
Rokrok & siihen ralliin!!!
