Cableguys PanCake 2 updated to 2.3.2 (Apple Silicon native)
Cableguys updated their free planning plugin:
https://www.cableguys.com/pancake
Re: UVI Workstation updated to 4.0.0
James Steele wrote: Wed Mar 05, 2025 3:31 pm UVI Workstation updated to 4.0.0
4.0.0
- New browser with tags, audio previews, improved search and favorites
- UI refinements and optimized layout
- Sync engine features with Falcon 3.1.1
- New UVI Starter soundpack, featuring 50 UVI hand-crafted presets
I'm not too sure I'm on board with this update. Looks like it wants to be Kontakt browserwise, but the biggest problem I had was that it seemed to forget the MOTU instruments disk location. After I opened the "Files" view instead of the "Library" view, and navigated to the disk location, it seemed to remember the directory mapping thereafter.
The "Starter" files seemed to be OK, but took up over 2G on my home disk.
Not that big a deal for me as I use Falcon primarily anyway.
APU Software Updates
Looks like a few revisions went out quickly. Now at version 3.4.5
https://apu.software/download/
Release Notes
Version 3.4.5
• Swap panel texture
Version 3.4.4
• Improve meter texturing
• Tweak light mode colors
Version 3.4.3
• Fix histogram sample expiration during history resize
A.O.M. Plugin Updates (including Invisible Limiter series)
Looks like there have been a couple updates since I last updated to 11.8.1.
https://aom-factory.jp/download/
Version History
Version 1.18.3 (2025-02-02)
Bugfixes
• [macOS][VST3] Fixed wrong drawing location in Studio One 7.1.
Version 1.18.2 (2025-01-24)
New Features
• [Invisible Limiter, Invisible Limiter G2, Invisible Limiter G3, tranQuilizr, tranQuilizr G2] Added a dialog to set initial parameter values ​​for new instances.
Bugfixes
• [All Plugins] Host project does not enter into modified state after text input. This issue occurred in v1.18.0. – fixed.
• [All Plugins] The text input operation was not registered in the plugin’s undo history. This issue occurred in v1.18.0. – fixed.
• [Cyclic Panner] If LPF link is enabled, the plugin may bypass pre-playback internal state initialization when resuming playback. This issue occurred in v1.18.0. – fixed.
• [DeSibilizer, DeSibilizer LL, Invisible Limiter LL, Stereo Imager D, Wave Shredder] The plugins may bypass pre-playback internal state initialization when resuming playback. This issue occurred in v1.18.0. – fixed.
• [Invisible Limiter G2, tranQuilizr G2] The plugins may output past input signals while resuming playback. This issue appears to have existed since the initial release of the plugin. – fixed.
• [Kujaku, Nu Compressor, Tau Compressor Plus, tranQuilizr, tranQuilizr G2, Triple Fader] Fixed a bug where DAW project does not get marked as changed when operating plugin’s internal parameters. This issue occurred in v1.18.0.
• [Kujaku] Fixed a bug where the internal state may not be initialized when playback is resumed when Decimation and/or Saturation effects are enabled. This issue appears to have existed since the initial release of the plugin.
• [Kujaku] Fixed an issue where the label in the mouse settings dialog was cut off. This issue occurred in v1.18.0.
• [Nu Compressor] Fixed a bug where the internal state might not be initialized when playback resumes if the side-chain filter was enabled. This issue occurred in v1.18.0.
• [VST2] Fixed a bug that could cause the plugin to recognize incorrect sampling frequency. This issue occurred in v1.18.0.
Change
• [Invisible Limiter, Invisible Limiter G2, Invisible Limiter G3, tranQuilizr, tranQuilizr G2] For some parameters, the user’s latest settings were automatically memorized and used as the initial values ​​for new instances, but this behavior has been replaced by a dedicated settings dialog.
Re: Audio Modeling Solo Strings 3.9.1
cuttime wrote: Thu Mar 06, 2025 4:03 pm No update info that I can find.
Speaking of which:
V 3.9.1
[March 4th, 2025]
FIX
- Improved performance and overall stability, especially when multiple instances are loaded and running simultaneously.
- Enhanced accessibility for screen readers / VoiceOver in notifications and the notification center.
- Room Simulator: minor UI improvements.
- Room Simulator: fixed an issue that, in certain conditions, caused inconsistent delay in late reverb reflections.
- AUM: fixed a crash when used as an AUv3 plugin in the AUM host on iPhone.
- Presets: fixed import for presets created with older extensions.
- AUv3: minor UI improvements.
Steinberg Groove Agent and Groove Agent SE updated to 5.2.20
Run Steinberg Download Assistant to update
wdegillio
Re: Xfer Records Serum 2 Update
Post by wdegillio »
After much speculating, name-calling, hand-wringing and drama on certain other message boards, Steve Duda (of Xfer Records) has released Serum 2! Better yet, it is a free update for owners of the original version.
Happy St. Patrick's Day!
Bandcamp - https://billgdegillio.bandcamp.com
YouTube - https://www.youtube.com/channel/UCzYInT ... 53N-Rs3c-g
Instagram - billgdegillio
Mac Mini M4* 24 gigs RAM* OS 15.5* DP 11.34* MOTU M4* Scuffham S-Gear* Sibelius*
Xfer Records Serum 2 & Nerve* u-he Zebra2 & Hive* NI Komplete 13* Korg Legacy Collection*
M-Audio Oxygen Pro 61* Presonus Central Station* Dynaudio BM5a* Audiio-Technica ATH-M40x & Grado SR225 Headphones
Release Notes
Version 3.4.6
Improved raster contrast/precision
Support vertical raster orientation (meter)
UVI Workstation updated to 4.0.1
4.0.1
- Fix possible crash when loading multi
- UI fixes
Vienna Synchron Player updated to 1.3.2148
v1.3.2148, March 18th, 2025
Added:
• Flow View for Synchron Woodwinds and Synchron Special Woodwinds
• Minor performance and stability tweaks
Boz Digital Bark of Dog 3 updated to 3.0.1
Not sure when this happened but it is updated.
https://www.bozdigitallabs.com/my-account/downloads/
Re: UVI Workstation updated to 4.0.1
James Steele wrote: Tue Mar 18, 2025 9:29 pm UVI Workstation updated to 4.0.1
4.0.1
- UI fixes
We won't bother going down the same rabbit hole again this time of course, but FWIW James, UVI has stuffed-up the same way again.
In my account downloads, I only see:
"VERSION: 4.0.0 | Updated: 2025/03/05"
:lol:
Thanks for the heads-up brother; I'll keep an eye on the page...
monkey man wrote: Tue Mar 18, 2025 11:32 pm
4.0.1
- UI fixes
:lol:
I assume that's because you are downloading from their website and not via UVI Portal. I always update via the UVI Portal app. Is there a reason you don't use UVI Portal?
Here. If it helps I will temporarily make it downloadable from here:
<File Removed>
Once you have it... let me know. I don't want to run afoul of UVI. :?
apulSoft Updates
apulSoft Updates
apVerb updated to 1.2.3
https://apulsoft.ch/apverb/
apQualizr2 updated to 2.7.4
https://apulsoft.ch/apqualizr2/
apTrigga3 updated to 3.7.4
https://apulsoft.ch/aptrigga3/
