Cableguys PanCake 2 updated to 2.3.2 (Apple Silicon native)
Cableguys updated their free planning plugin:
https://www.cableguys.com/pancake
Re: UVI Workstation updated to 4.0.0
I'm not too sure I'm on board with this update. Looks like it wants to be Kontakt browserwise, but the biggest problem I had was that it seemed to forget the MOTU instruments disk location. After I opened the "Files" view instead of the "Library" view, and navigated to the disk location, it seemed to remember the directory mapping thereafter.James Steele wrote: ↑Wed Mar 05, 2025 3:31 pm UVI Workstation updated to 4.0.0
4.0.0
- New browser with tags, audio previews, improved search and favorites
- UI refinements and optimized layout
- Sync engine features with Falcon 3.1.1
- New UVI Starter soundpack, featuring 50 UVI hand-crafted presets
The "Starter" files seemed to be OK, but took up over 2G on my home disk.
Not that big a deal for me as I use Falcon primarily anyway.
APU Software Updates
Looks like a few revisions went out quickly. Now at version 3.4.5
https://apu.software/download/
Release Notes
Version 3.4.5
• Swap panel texture
Version 3.4.4
• Improve meter texturing
• Tweak light mode colors
Version 3.4.3
• Fix histogram sample expiration during history resize
A.O.M. Plugin Updates (including Invisible Limiter series)
Looks like there have been a couple updates since I last updated to 11.8.1.
https://aom-factory.jp/download/
Version History
Version 1.18.3 (2025-02-02)
Bugfixes
• [macOS][VST3] Fixed wrong drawing location in Studio One 7.1.
Version 1.18.2 (2025-01-24)
New Features
• [Invisible Limiter, Invisible Limiter G2, Invisible Limiter G3, tranQuilizr, tranQuilizr G2] Added a dialog to set initial parameter values for new instances.
Bugfixes
• [All Plugins] Host project does not enter into modified state after text input. This issue occurred in v1.18.0. – fixed.
• [All Plugins] The text input operation was not registered in the plugin’s undo history. This issue occurred in v1.18.0. – fixed.
• [Cyclic Panner] If LPF link is enabled, the plugin may bypass pre-playback internal state initialization when resuming playback. This issue occurred in v1.18.0. – fixed.
• [DeSibilizer, DeSibilizer LL, Invisible Limiter LL, Stereo Imager D, Wave Shredder] The plugins may bypass pre-playback internal state initialization when resuming playback. This issue occurred in v1.18.0. – fixed.
• [Invisible Limiter G2, tranQuilizr G2] The plugins may output past input signals while resuming playback. This issue appears to have existed since the initial release of the plugin. – fixed.
• [Kujaku, Nu Compressor, Tau Compressor Plus, tranQuilizr, tranQuilizr G2, Triple Fader] Fixed a bug where DAW project does not get marked as changed when operating plugin’s internal parameters. This issue occurred in v1.18.0.
• [Kujaku] Fixed a bug where the internal state may not be initialized when playback is resumed when Decimation and/or Saturation effects are enabled. This issue appears to have existed since the initial release of the plugin.
• [Kujaku] Fixed an issue where the label in the mouse settings dialog was cut off. This issue occurred in v1.18.0.
• [Nu Compressor] Fixed a bug where the internal state might not be initialized when playback resumes if the side-chain filter was enabled. This issue occurred in v1.18.0.
• [VST2] Fixed a bug that could cause the plugin to recognize incorrect sampling frequency. This issue occurred in v1.18.0.
Change
• [Invisible Limiter, Invisible Limiter G2, Invisible Limiter G3, tranQuilizr, tranQuilizr G2] For some parameters, the user’s latest settings were automatically memorized and used as the initial values for new instances, but this behavior has been replaced by a dedicated settings dialog.
Re: Audio Modeling Solo Strings 3.9.1
V 3.9.1
[March 4th, 2025]
FIX
- Improved performance and overall stability, especially when multiple instances are loaded and running simultaneously.
- Enhanced accessibility for screen readers / VoiceOver in notifications and the notification center.
- Room Simulator: minor UI improvements.
- Room Simulator: fixed an issue that, in certain conditions, caused inconsistent delay in late reverb reflections.
- AUM: fixed a crash when used as an AUv3 plugin in the AUM host on iPhone.
- Presets: fixed import for presets created with older extensions.
- AUv3: minor UI improvements.
Speaking of which:
V 3.9.1
[March 4th, 2025]
FIX
Steinberg Groove Agent and Groove Agent SE updated to 5.2.20
Run Steinberg Download Assistant to update
Re: Xfer Records Serum 2 Update
After much speculating, name-calling, hand-wringing and drama on certain other message boards, Steve Duda (of Xfer Records) has released Serum 2! Better yet, it is a free update for owners of the original version.
Happy St. Patrick's Day!
Bandcamp - https://billgdegillio.bandcamp.com
YouTube - https://www.youtube.com/channel/UCzYInT ... 53N-Rs3c-g
Instagram - billgdegillio
Mac Mini M4* 24 gigs RAM* OS 15.4* DP 11.34* MOTU M4* Scuffham S-Gear* Sibelius 8*
Xfer Records Serum & Nerve* u-he Zebra2 & Hive* NI Komplete 13* Korg Legacy Collection*
M-Audio Oxygen Pro 61* Presonus Central Station* Dynaudio BM5a* Audiio-Technica ATH-M40x & Grado SR225 Headphones
Release Notes
Version 3.4.6
Improved raster contrast/precision
Support vertical raster orientation (meter)
UVI Workstation updated to 4.0.1
4.0.1
- Fix possible crash when loading multi
- UI fixes
Vienna Synchron Player updated to 1.3.2148
v1.3.2148, March 18th, 2025
Added:
• Flow View for Synchron Woodwinds and Synchron Special Woodwinds
• Minor performance and stability tweaks
Boz Digital Bark of Dog 3 updated to 3.0.1
Not sure when this happened but it is updated.
https://www.bozdigitallabs.com/my-account/downloads/
Re: UVI Workstation updated to 4.0.1
We won't bother going down the same rabbit hole again this time of course, but FWIW James, UVI has stuffed-up the same way again.James Steele wrote: ↑Tue Mar 18, 2025 9:29 pm UVI Workstation updated to 4.0.1
4.0.1
- UI fixes
In my account downloads, I only see:
"VERSION: 4.0.0 | Updated: 2025/03/05"
Thanks for the heads-up brother; I'll keep an eye on the page...
I assume that's because you are downloading from their website and not via UVI Portal. I always update via the UVI Portal app. Is there a reason you don't use UVI Portal?monkey man wrote: ↑Tue Mar 18, 2025 11:32 pmWe won't bother going down the same rabbit hole again this time of course, but FWIW James, UVI has stuffed-up the same way again.James Steele wrote: ↑Tue Mar 18, 2025 9:29 pm UVI Workstation updated to 4.0.1
4.0.1
- UI fixes
Here. If it helps I will temporarily make it downloadable from here:
<File Removed>
Once you have it... let me know. I don't want to run afoul of UVI.
apulSoft Updates
apulSoft Updates
apVerb updated to 1.2.3
https://apulsoft.ch/apverb/
apQualizr2 updated to 2.7.4
https://apulsoft.ch/apqualizr2/
apTrigga3 updated to 3.7.4
https://apulsoft.ch/aptrigga3/
