Re: UVI Falcon updated to 3.1.1
James Steele wrote: Sat Oct 26, 2024 9:06 pm UVI Falcon updated to 3.1.1
And damned if I can find a changelog for 3.1.1. There's no link in the info window in UVI Portal except to the manual.
Looks like (at least for me) UVI Portal is still wonky and it downloads the Falcon dmg and tells you it has installed it but it hasn't. You have to go into Downloads folder and open the dmg file and then launch the pkg.
Seems to be fixed. The portal launched the dmg, and I was prompted to do all the usual responses to an installer. Finder reports that I have 3.1.1.
corbo-billy
Drumazon 2 version 2.0.6.
Post by corbo-billy »
Drumazon 2 updated to version 2.0.6.
Fixed
- Automation issues for Mute / Solo buttons
- Drum Map Ul labels
- Issue with updating dirty state for Pattern Name
- Reduced CPU consumption for idle processing
https://d16.pl/drumazon2
Nepheton 2 updated to version 2.0.3
Fixed
https://d16.pl/nepheton2
Nithonat 2 updated to version 2.0.1
Fixed
https://d16.pl/nithonat2?utm_source=d16 ... ithonat201
LUSH 2 updated to version 2.0.2
Added
- Save icons on GUI for the Layer and Arpeggio presets
- Layer activity indication in MIDI Zones editor
- Changing View can be assigned to MIDI CC
Changed
- Minor GUI changes
Fixed - LFO Phase parameter wasn't refreshed
until currently playing notes ended - LFOs in Sync mode set with different
Rate values diverged after some time
- Inconsisency between visual feedback and actual
Portamento Time parameter when automated - GUI flicker in some specific scenarios
when enumerated parameters where changed - Issue with double-click initialization for Voice Volume
parameter in Modulation Matrix - Increased precision for presenting parameters values
which are expressed in percents
- Minor bugs
https://d16.pl/lush2
Find Any File updated to 2.5.3
Since a lot of folks use this utility, thought I'd post. You should be prompted to update automatically when you launch Find Any File.
What's changed in 2.5.3
Fixes a crash when denying Local Network access in macOS 15 Sequoia.
Fixes a crash when searching for File Content with RegEx.
Keeps working if Clean My Mac 5 removes unused language files.
Won't scroll back any more after selecting items in Icon Preview mode.
Won't open an extra window any more when using "Find All".
The Open With command lists now the same default app as Finder does.
The Open command in the Results window now shows the app that'll open the selected file.
Closing a Find window that was opened from a .faf file won't ask to save any changes any more unless you set the hidden preference "Closing Find windows with unsaved changes asks to save" to YES.
Steinberg updates including bug fix for Spectral Layers 11
Steinberg Download Assistant will self-update today when you run it.
There is then a new version, Spectral Layers 11.0.40 which I assume should fix the blank display problem when opening a project. Just found the list of changes: https://www.steinberg.net/spectralayers ... -notes/11/
SpectraLayers 11.0.40
October 28, 2024. We’re happy to announce the availability of the SpectraLayers 11.0.40 maintenance update. This new version introduces many issue resolutions and improvements throughout the application. This is also the first version of SpectraLayers that supports the AAX format and can be loaded as an ARA plug-in in Pro Tools.
Improvements and New Features
• SpectraLayers 11.0.40 can now be used in ARA mode in Pro Tools (version 2024.10 required).
• Additional bitrate options are available for exporting multichannel projects.
• More customizable mouse shortcuts have been added.
• The size of the Module Presets selector has been increased.
Stability and Performance
• SpectraLayers now performs accurate delay compensation when loaded as an ARA extension in Cubase and Studio One.
• When using the Playback tool with a limited frequency range, the playhead now properly mirrors what is being played.
• Using the DeClick module no longer creates audio artifacts at the beginning of a selection.
• Rendering or removing SpectraLayers as an ARA extension and then undoing it now works as expected.
Sonoma 14.7.1 update available
Looks mostly like security fixes, etc. Can't imagine it's too risky. I'm on 14.7, so I'm going to go for it.
https://support.apple.com/en-us/121570
Doing a Time Machine backup right now.
Re: Sonoma 14.7.1 update available
James Steele wrote: Mon Oct 28, 2024 4:36 pm Sonoma 14.7.1 update available
Seems harmless enough. Updating sig now.
Re: SSL Updates
monkey man wrote: Wed Oct 23, 2024 7:23 pm
James Steele wrote: Tue Oct 22, 2024 1:40 pm SSL Updates
Just launched SSL Download Manager, and X-EQ 2 and FlexVerb have been updated. FlexVerb to 6.8.9 and X-EQ 2 to 6.7.2. I clicked the "i" but no update notes available. Other SSL plugs that I don't own may be updated as well.
Note to whom it may concern:
If you like to keep the installers, the individual downloads on the site haven't been updated yet:
https://support.solidstatelogic.com/hc/ ... nloads-0-0
I've been waiting several days. In the past I've emailed support and informed them but I'm not playing that game anymore; it's not my job to tell them how to do their job. :lol:
Just a heads-up that the latest X-EQ 2 and FlexVerb installers have finally made it to the download page. :headbang:
Addictive Drums 2.5 updated to 2.5.1
Just ran XLN Online Installer and saw this.
Addictive Drums 2 2.5.1 - Oct 28, 2024
• Updated to support Vintage Dead
• Fixed issue with incorrect rendering in Cubase
• Various fixes/tweaks to tutorials
• New midimaps for Alesis drums
• Fixed rare crash on windows due to unhandled structured exceptions
• Various tweaks to interface, manual and helptips
• Increased number of available voices
• Misc. small performance improvements
Calagan
Post by Calagan »
Any feedback on macOS 14.7.1 ?
Calagan wrote: Wed Oct 30, 2024 5:30 am Any feedback on macOS 14.7.1 ?
Seems to be working just fine (for me).
Calagan
Post by Calagan »
James Steele wrote: Wed Oct 30, 2024 11:07 am
Coool. Thanks for the feedback...
Steinberg Media Bay and HALion updates
Just ran Steinberg Download Assistant which prompted a Media Bay update to 1.2.0.23
Also HALion is updated to 7.1.10. Whole bunch of fixes so if you want to know what they are, best look at the PDF.
corbo-billy
Yes, I confirm .
Antares Updates... switching to iLok licenses
Just saw a post about this on Avid DUC. Antares has updates and they're switching to iLok for licensing.
Launch Auto-Tune Central and it walks you through it. Was pretty painless. You have to link your iLok account and yes, you will be prompted by the iLok server to verify with your password, but it is not risky... not retained by Antares AFAIK. I did it and now have my licenses for AVOX DUO and AVOX CHOIR on my iLok dongle which is my preference.
In fact, just hit 500 licenses on my iLok dongle!
:woohoo:
Cool thing is apparently Antares old copy protection involved CodeMeter which as I recall from Mike Halloran's posts is some sketchy stuff?
Re: Antares Updates... switching to iLok licenses
Here's a video about it. I had no issues though just following along with the Updater...
