Bundles mess
Gabe S.
Re: Bundles mess
Post by Gabe S. »
Hey guys.
Just to check in here: I was mentioning that I rebuilt my template fresh and made it a Stationary Pad instead of a template. I have to say I have been creating many projects with the new Stationary Pad "template", and it's been holding up here on every open. It hasn't failed yet.
So, I'm cautiously saying that I have a successful workaround by rebuilding the template and making it a Stationary Pad.
However, in the other active thread about this started by "thealps", he rebuilt a session and seemed ok until he made multiple sequences within one session and then started having problems----if I understand his postings correctly.
Anyway, just thought I'd add another note to this topic.
Anyone else care to test the theory of rebuilding from complete scratch? I know it's a pain.....
Cheers.
-gabe
Computer: 2019 Mac Pro 28-core 2.5gHz, OS 10.15.2, 96GB ram, all SSD/NVME drives, MH Labs ULN-8, MOTU MidiTimepiece AV
DP Setup: DP10.11, all Spectrasonics VIs, all Waves plugins, Sonnox AU, Altiverb, NI Komplete 12/K5+6, Plogue Bidule 64 as VI host
Re: Bundles mess
Stationary works fine for me too. I have had a problem in a project with two sequences using the same bundles. Deleting one sequence, the first created, discombobulated DP and removed the bundles used by the second.
I also had a problem once when I started DP without powering up the audio interface. The bundles all disappeared then too, but I haven't seen that occur regularly. I wondered if that was a problem that started in AudioMIDI and worked its was into DP.
Re: Bundles mess
"Discombobulated"?
Crikey, Baysey. :shock:
Re: Bundles mess
monkey man wrote:"Discombobulated"?
It was awful. Blood everywhere.
Gabe S.
Re: Bundles mess
Post by Gabe S. »
(hehe actually, discombobulated simply means confused......if he were to say disemboweled or decapitated....now that would be gruesome!) :)
-g
Dan Worley
Re: Bundles mess
Post by Dan Worley »
In case you didn't see this, there's a possible workaround that may save people a lot of time and trouble. Hopefully it will work for many of you and also lead to the final fix.
http://www.motunation.com/forum/viewtop ... =1&t=44257
c-ya,
Dan Worley
DP10.13
