https://www.plugin-alliance.com/en/prod ... alion.html
Verstion 1.0.6 (Sep 17, 2024)
- Hotfix. Battalion was not resizing correctly in formats other than VST3.
Version 1.0.5 (Sep 11, 2024)
- Add NKS support.
- Add Scrapyard synth engine, a blend of FM and Modal.
- Add MiniGlitch and MegaGlitch distortion effects.
- Add Contrast distortion effect.
- Add Square distortion effect.
- Add Dropout distortion effect.
- Add MIDI note controls to start or stop playback.
- Add MIDI note controls to toggle Mute and Solo status.
- Add MIDI note controls to control randomization and performance.
- Add MIDI note controls to change presets.
- Add MIDI note controls to manually choke drum channels.
- The play/stop status is now saved with DAW projects.
- The reverb control no longer jumps unpredictably when clicked and behaves more like the other knobs.
- Fixed a bug where sampler controls were not updating with correct engine tooltips.
- Fixed a hard crash in Pro Tools when clicking a drop-down on the sequencer page.
- Added a "Show User Sample Folder" shortcut to the sample selection menu.
- Fixed a bug where "Free Run" LFOs weren't resetting when the DAW's transport was restarted.
- "Load Sample..." now remembers the last folder opened during a session.
- Significant optimizations to GUI rendering.
- Performance: removed unnecessary repaints on envelope visualizers, sample visualizer, and play button (50% CPU gain)
- Performance: fixed infinite loop bug in sample loader
- Performance: fixed bug causing some minimized states on interface to use +100% CPU
