corbo-billy
Post by corbo-billy »
Unfiltered Audio Battalion - Changelog
https://www.plugin-alliance.com/en/prod ... alion.html
Verstion 1.0.6 (Sep 17, 2024)
- Hotfix. Battalion was not resizing correctly in formats other than VST3.
Version 1.0.5 (Sep 11, 2024)
- Add NKS support.
- Add Scrapyard synth engine, a blend of FM and Modal.
- Add MiniGlitch and MegaGlitch distortion effects.
- Add Contrast distortion effect.
- Add Square distortion effect.
- Add Dropout distortion effect.
- Add MIDI note controls to start or stop playback.
- Add MIDI note controls to toggle Mute and Solo status.
- Add MIDI note controls to control randomization and performance.
- Add MIDI note controls to change presets.
- Add MIDI note controls to manually choke drum channels.
- The play/stop status is now saved with DAW projects.
- The reverb control no longer jumps unpredictably when clicked and behaves more like the other knobs.
- Fixed a bug where sampler controls were not updating with correct engine tooltips.
- Fixed a hard crash in Pro Tools when clicking a drop-down on the sequencer page.
- Added a "Show User Sample Folder" shortcut to the sample selection menu.
- Fixed a bug where "Free Run" LFOs weren't resetting when the DAW's transport was restarted.
- "Load Sample..." now remembers the last folder opened during a session.
- Significant optimizations to GUI rendering.
- Performance: removed unnecessary repaints on envelope visualizers, sample visualizer, and play button (50% CPU gain)
- Performance: fixed infinite loop bug in sample loader
- Performance: fixed bug causing some minimized states on interface to use +100% CPU
APU Software Updates
https://apu.software/download/
APU Software Loudness Compressor, Loudness Meter, and Dynamics Optimizer have been updated from 2.9.2 to 3.0.0.
Version 3.0.0
• Set channel-split LUFS channels as dual-mono for consistent loudness
• Look-ahead performance improvement (compressor/optimizer)
• Remove negative look-ahead for limiter (optimizer)
• Fix rare source max percentile range detection inaccuracy (optimizer)
• Fix expansion ratio text parsing (compressor)
• Support lower visualizer delta field decay rates
• Filename in title bar (optimizer/meter)
• Initial limiter release (limiter)
SteerMouse updated to 5.7.2
https://plentycom.jp/en/steermouse/download.php
5.7.2 (Oct 3, 2024)
Now supports Logitech MX ERGO S.
Now supports Razer Naga V2 HyperSpeed. (USB connection only, not Bluetooth.)
Problem solved where wheel mode would not change on Logitech MX Master/Anywhere.
Problem solved where dragging with another device would not work.
Eventide Updates
Post by Rick Cornish »
From Eventide this morning:
"New Minimum OS Requirements & macOS Sequoia Support
All Eventide plug-ins have been updated with new minimum OS requirements: macOS 10.14 Mojave and Windows 10 are now the oldest supported operating systems.
In addition, we have completed testing and all Eventide plug-ins are fully compatible with macOS Sequoia.
We've fixed many bugs in this latest release and full changelogs can be found on our website.
Happy mixing!"
Get the latest installers here.
Re: Eventide Updates
Rick Cornish wrote: Tue Oct 08, 2024 11:27 am From Eventide this morning:
Happy mixing!"
Woohoo! Thanks for sharing this, Rick! Looks like I have a fun day of downloading ahead of me! :) Anthology is now 1.3.3. (Previously was 1.2.0, IIRC)
I already had it installed before I got the email this afternoon.
Here are the Anthology 1.3.3 release notes:
1.3.3
Updated the supported minimum OS to macOS 10.14 for all plug-ins
Improved the fidelity of the Tonal Pitch Shifter's 'Poly' mode for the 'Percussion Set' Source Type in Physion Mk II
Updated the EULA date, which was incorrectly set to 2023
Fixed a bug in Precision Time Align where audio would not pass at certain sample delay amounts
Fixed a bug in EChannel, EQ45, EQ65, Physion Mk II, and UltraChannel where audio did not pass when the plug-in was saved as deactivated in a session and then reactivated after reloading the session
Fixed a bug in Physion Mk II and SplitEQ where parameters would reset to their defaults when the plug-in was made inactive/reactivated or a track containing the plug-in was frozen/unfrozen in Pro Tools
Fixed several bugs in Physion Mk II where the dry signal path, transient signal path, and tonal signal path were not properly sample-aligned and delay compensated at certain settings and sample rates
Fixed a bug in EChannel and UltraChannel where the Xformer control would process audio slightly differently at different sample rates
Fixed a bug in SplitEQ where the Tutorial videos would not display if the plug-in UI was launched with the Tutorial already started
Fixed a bug in Physion Mk II and SplitEQ where multiple Tutorial windows could end up overlapping if the Tutorial was restarted while already open
Fixed a bug in Physion Mk II and SplitEQ where meters would occasionally display incorrect and pixelated background colors
Fixed a bug in SplitEQ and Physion Mk II where the UI appeared darker than intended in Pro Tools
Tracktion/Wavesequencer Updates
Theia 1.16 updated to 1.17
Hyperion 1.59 updated to 1.60
PluginDoctor updated from 2.3.6 to 2.3.7
https://ddmf.eu/plugindoctor/
2024/10/07: v2.3.7 lowered total IMD measurement level to stay below 0 dBFS
Apogee Clearmountain Spaces 1.0.7
This probably happened a while ago. I missed it. I had 1.0.6. Apogee doesn't seem to send out emails so I just checked and this was now version 1.0.7. Looks like only big change is Apple Silicon native support for AAX.
https://apogeedigital.com/download-files/
Altiverb 8.0.9 update
https://www.audioease.com/altiverb/
This seems to have been out since 9/23/24. I just noticed it now.
The Altiverb 8 installer now also works on macOS 15 (Sequoia).
SteerMouse updated to 5.7.3
5.7.3 (Oct 7, 2024)
Problem solved where the app would not open on macOS 10.14 to 10.15.
Steinberg Spectral Layers 11 updated to 11.0.30
I actually missed this because I periodically launch Steinberg Download Manager to see if there are any alerts and there wasn't for this. You have to click SpectralLayers 11 in the "My product downloads" pane and then you will see that the button says "Install" instead of "Install again."
Here's what's new:
SpectraLayers 11.0.30
October 2, 2024. We’re happy to announce the availability of the SpectraLayers 11.0.30 maintenance update. This new version introduces many issue resolutions and improvements throughout the application.
Improvements and New Features
• 3D channel configurations, such as Dolby Atmos and Ambisonics, with up to 16 channels are now supported.
• When exporting only one layer, the name of the file is automatically assigned to the layer.
• Selection events can now be excluded from the editing history.
• The efficiency of the DeClick module has been improved.
• The ARA display range has been improved, so that the selected clip is always visible.
• Mouse wheel and touchpad navigation have been improved.
Stability and Performance
• An audio dropout issue when switching between projects has been resolved.
• The waveform power scrollbar now matches the default scale of +3 dB.
• An issue when creating display and module filters has been resolved.
• Multiple issues with the VST 3 effects module have been resolved.
• An issue when loading audio files on macOS 11 has been resolved.
• Enabling both Composite Layers view and the layer envelope no longer renders the application unreliable.
• An issue when zooming a selected range has been resolved.
• An issue when rendering waveforms without smoothing has been resolved.
• Module presets are now properly saved in ARA mode.
• A sync issue when exporting transcriptions as CSV files has been resolved.
Kontakt Factory Library 2 updated to 1.4.1
Release Notes
Version 1.4.1 2024-10-10
FIXED
"Drum Piece" table misalignment on "Mixer" pages
Arturia Analog Lab Pro updated from 5.10.5.5098 to 5.10.6.5147
Analog Lab Intro also updated. Run Arturia Software Center to update.
