Kontakt 7.10.4 released today
As always I'm going to make sure I backup and have APFS snapshot first.
Release Notes
Version 7.10.4 2024-05-21
FIXED
DAW project files containing Kontakt no longer increase following each resave
FIXED
In Edit View the Ul of the Kontakt FX Freak was incorrectly initialized
KNOWN ISSUE
Intermittent crashes when Kontakt 7 is used with the following combination: Logic Pro 10.x, macOS 14, Kontrol S MK3. The issue no longer occurs in Logic Pro 11
KNOWN ISSUE
Intermittent visual glitches and computer shutdown when using Kontakt on Apple M2 / M3 computers in clamshell mode, or when Kontakt is hosted in GarageBand. The issue no longer occurs on macos 14.5
KNOWN ISSUE
In Pro Tools, Kontakt window is cropped when zooming larger than available display size
KNOWN ISSUE
Please note that if you have updated to Kontakt 7.10. from a version before 7.9, you may need to reselect your audio device on first launch (macOS only)
Re: Aturia Updates Analog Lab 5.10.1.4686 to 5.10.2.4741
James Steele wrote: Tue May 21, 2024 11:58 am Aturia Updates Analog Lab 5.10.1.4686 to 5.10.2.4741
V 5.10.2
New features
Added compatibility for MiniBrute V
Run Arturia Software Center to update
Heads up on this Arturia update. I had a little bit of a hiccup. First time I ran the Analog Lab (Pro) update, when I tried to then run the standalone Analog Lab app, I got this error message:
I then "Reinstall" from the Arturia Software Center, but all it did was uninstall and not begin downloading the package to do the reinstall. I tried going to Arturia's website to get the installer directly, and they were having issues. Eventually, I guess things were fixed and I clicked "Reinstall" and it finally proceeded to "Downloading" again and now all is well and the standalone works fine.
dix
Post by dix »
Sound Particles' free database search browser Explorer 2.2 now spots to DP! ...a first for sound databases as far as I know.
https://soundparticles.com/products/explorer?a=4apVa
dix wrote: Wed May 22, 2024 3:08 pm Sound Particles' free database search browser Explorer 2.2 now spots to DP! ...a first for sound databases as far as I know.
Interesting! I'll have to try and check it out soon. I bought this one not that long ago. Need to compare it.
https://www.sononym.net/
dix
Post by dix »
James Steele wrote: Wed May 22, 2024 3:16 pmInteresting! I'll have to try and check it out soon. I bought this one not that long ago. Need to compare it.
That looks cool. More for music than sound effects it looks like. Does it spot to DP?
dix wrote: Wed May 22, 2024 3:30 pm
I don't think it "spots" per se. You can drag and drop to the timeline in DP. Oddly enough, I wanted it mostly to catalog sound effects, but I'm also using it for drum loops, risers, etc. Stuff that I probably will never use. :lol:
dix
Post by dix »
James Steele wrote: Wed May 22, 2024 4:26 pmI don't think it "spots" per se. You can drag and drop to the timeline in DP
Right. Drag and drop is how all databases work. The ability to Spot from the app directly to the Wiper position in a track in DP is the headline here. Spotting is how database apps have always worked with ProTools and most other DAWs - it can be a dramatic workflow improvement and time saver when working with sound effects.
As far as I know Explorer is the first and only database app that can Spot to DP. Good on Sound Particles for bringing this basic functionality To DP finally.
dix wrote: Wed May 22, 2024 4:57 pmAs far as I know Explorer is the first and only database app that can Spot to DP. Good on Sound Particles for bringing this basic functionality To DP finally.
Nice! And it's FREE you say? Hmmmm... wonder how they can do that? I will definitely need to check it out!
dix
Post by dix »
James Steele wrote: Wed May 22, 2024 4:59 pm
I think mainly it’s a loss leader for their other products, plus there is an in-app subscription sound effects library option.
Honestly the GUI is a little slow currently, but I asked Sound Particles support about it and they said they were working on it.
Arturia SQ80 V 1.6.0.4395 updated to 1.6.1.4687
One of the components in my Arturia V Collect 9 updated today.
V 1.6.1
Bugfixes
Fixed parameters that no longer display decimals on the GUI
Launch Arturia Software Center to update.
AudioSwift 2.3.8 update
New version of AudioSwift out. This is an app that lets you turn your Magic Trackpad into a MIDI controller that can do a number of useful things. The developer is always refining it.
https://audioswiftapp.com/try-out-these ... 42a8e56057
Pulsar Modular updates P455 MDN Sidecar and P450 MDN EQ
Relatively minor update to both of these plugins.
https://www.pulsarmodular.com/product/p455-mdn-sidecar/
Bypass parameter synchronizes with the Bypass of the DAW (those that support this feature).
Audio Hijack updated from 4.4.1 to 4.4.2 "CRITICAL UDPATE"
This is described as a critical update, FWIW. Here are the notes about it:
Corrections for Default Settings for VolP apps in the New "Audio Device
Selection" Section of the "Application" Block
This update fixes a critical issue where attempting to capture from a VolP app like Zoom or Skype could result in no audio being recorded. Due to an incorrect migration of existing sessions from Audio Hijack 4.4.0 or earlier, setups where a VolP app was playing to a non-default output would not see any audio.
Audio Hijack now correctly defaults the "Audio Device Selection" option to "Capture audio played to all output devices" for VolP applications. Thanks to Jason Snell for the heads-up on this issue.
Audio Hijack 4.4.2 ls for MacOS 14.4 and Higher
This variant of Audio Hijack supports MacOS 14.4 and higher. On MacOS 11 through 14.3.1, a different variant is automatically used, with no action required on your part.
Michael Canavan
Re: Audio Hijack updated from 4.4.1 to 4.4.2 "CRITICAL UDPATE"
Post by Michael Canavan »
James Steele wrote: Fri May 24, 2024 3:58 pm Audio Hijack updated from 4.4.1 to 4.4.2 "CRITICAL UDPATE"
Curious to find out if it fixes the issues I'm having with DP and Audio Hijack. I setup the IK ARC room correction software in ARC to get around having to turn it off to master things in DP, and recently it's decided to play only out of the right side speaker...
sayatnova
Re: Boz Digital Big Clipper 2 updated to 2.1.0
Post by sayatnova »
James Steele wrote: Mon May 20, 2024 10:00 pm Boz Digital Big Clipper 2 updated to 2.1.0
Boz really isn't very good about informing users of updates. I just did one of my periodic checks and discovered Big Clipper had been updated from 2.0.9 to 2.1.0. I have no idea what the changes were. Can't find them.
https://www.bozdigitallabs.com/product/big-clipper-2/
Nor porting everything to AS native versions, either... Frustrating.
http://www.bfdmusic.com
