UVI Workstation
Re: UVI Workstation
James Steele wrote: Fri Jun 30, 2023 11:40 am Ahhh that’s interesting… so you have to have a MachFive3 license on your iLok to open those images? Interesting. I almost removed that license. Glad I didn’t! I bet MOTU could probably help you out with another license so you don’t have to move your older ilok around. I have a Gen 2.
The updated libraries opened fine in Falcon stand alone except the MOTU Instruments (Incorrect Host error).
I have a Gen 3 iLok. For kicks, I removed the MachFive 3 license and tried again—didn't like that at all so I put it back and all was well.
Re: UVI Workstation
mikehalloran wrote: Fri Jun 30, 2023 3:45 pmThe updated libraries opened fine in Falcon stand alone except the MOTU Instruments (Incorrect Host error).
No problem opening MOTU Instruments on Falcon standalone here. I assume you have the iLok license for "MOTU Instruments?" It's available by request from MOTU. I didn't see it on my iLok at first, because the publisher listed as "UVI" not "Mark of the Unicorn."
Also, AFAICT, "MOTU Instruments.ufs" is the same content as the older "Universal Loops and Instruments.ufs" that it replaced.
Re: UVI Workstation
James Steele wrote: Fri Jun 30, 2023 4:08 pm
Thanks. Found the problem:
The build that I had installed was dated January 10, 2019. The one in Downloads is June 14, 2019. That one opened correctly.
This leaves another that I suspect might not be an error. I'm guessing that MOTU Instruments Lite.ufs can only be opened from within Performer Lite and DP (I can access it when I open PL projects in DP.) and not Falcon or UVI stand alone. I'll send in a TechLink and ask. Unlike MOTU Instruments.ufs, it does not require an iLok. Likewise, the chances that I would ecer want to do so are about zero.
Screenshot 2023-06-30 at 4.38.17 PM.png (47.96 KiB) Viewed 8577 times
Re: UVI Workstation
mikehalloran wrote: Fri Jun 30, 2023 4:52 pmI'm guessing that MOTU Instruments Lite.ufs can only be opened from within Performer Lite and DP (I can access it when I open PL projects in DP.) and not Falcon or UVI stand alone. I'll send in a TechLink and ask. Unlike MOTU Instruments.ufs, it does not require an iLok.
That would make total sense the that the "Lite" version would be crippled to only work in Performer Lite and DP. Especially since it doesn't require an iLok. I imagine relatively new users that would use Performer Lite would be prone to passing it around and sharing it if it didn't have limitations on it.
Re: UVI Workstation
James Steele wrote: Thu Jun 29, 2023 11:58 am • Mark79.ufs - (one interesting note: file size of old version was 3.43GB. This one is 7.44GB. I do not know why. Seems to sound the same.)
I asked here whether there is any point in getting these new files on a system still using macOS 10.14, but there was no answer. So I asked Matt at MOTU and he said there is no need with 10.14, but at 10.15 there appears to be some advantage. After that you need the new libraries to make them work properly with Falcon/UVI.
I also noticed that the Mark79 almost doubled in size. Matt suggested that this might be a result of consolidation of disk images from when the maximum size was the same as a regular DVD. But checking back to my original files and downloads, Mark79 was not one of those files that came in two ufs image. I’ve asked Matt why this might be but haven’t heard back.
Re: UVI Workstation
bayswater wrote: Fri Jul 07, 2023 12:21 pmSo I asked Matt at MOTU and he said there is no need with 10.14, but at 10.15 there appears to be some advantage. After that you need the new libraries to make them work properly with Falcon/UVI.
From what I understand, you'd want to download them to "future proof" them, because at some point when you update to an Apple Silicon Mac, those .ufs images will not open in Falcon or UVI Workstation (you will get a missing license error) unless you are running DP in Rosetta. So I would download one of the small ones, and verify that it works fine on Intel first and then carry on. Otherwise, when the day comes you get an Apple Silicon Mac you will need to do it anyway.
Yep. It's a puzzler. Ethno, which previously had two volumes, "Ethno.ufs" and "Ethno.ufs1" (if I recall the names correctly) was indeed consolidated into one volume which was about double the size. But you are right. Mark79 was just one volume and for some reason it blew up in size. At the time, I checked that it worked and just shrugged and moved on. :D
Re: UVI Workstation
James Steele wrote: Fri Jul 07, 2023 4:42 pm At the time, I checked that it worked and just shrugged and moved on. :D
Some of us remember when a Mac had a 1G internal drive and having 4G extra on it was a big deal. But you’re right — so what? I just want to make sure that there is nothing wrong with the file given that there is clearly something odd about it.
DrewFromKC
Re: UVI Workstation
Post by DrewFromKC »
I've been following this thread trying to get my old UVI soundbanks mounted to the newest version of UVI Workstation. I was able to get licenses for my old Plugsound Pro and Xteme FX soundbanks I bought from UVI years ago by providing serial numbers to those products on their website recently. I own MachFive 2 but never upgraded to MachFive 3 when it was still compatible with older Macs. Does this mean I cannot access my old MachFive 2 .ufs soundbanks in the UVI Workstation without upgrading to MachFive 3? (which seems silly since that software is currently incompatible with AS Macs and I would only be upgrading for access to the MachFive 3 soundbank libraries). Any thoughts?
Macbook M2 Pro, DP 11.3, MOTU 828mkII FW, UAD-2 TB3 Satellite QUAD, M-Audio Axiom 49, VI's and plugins.
Re: UVI Workstation
Rick Cornish wrote: Fri Jun 30, 2023 10:55 am
James Steele wrote: Thu Jun 29, 2023 11:58 am Yep... okay... so I just downloaded all of the following from this link and they all seem to open just fine in latest Apple Silicon native UVI Workstation and Falcon:
• Biosphere.ufs - (formerly MachFive Biosphere. If you have projects with any instances of Falcon or UVIWS that depended on the name of this volume being the same, I did try changing it in the Finder with no ill effects)
• F Grand 278.ufs
• JBass.ufs
• Percussiv.ufs
• StarDrums.ufs
• Telematic.ufs - (I actually never installed this previously, but downloaded it and it works fine)
• The Upright.ufs
• Universal Loops and Instruments.ufs - (Note that this is also same as MOTU Instruments.ufs AFAICT)
OK—I downloaded these files as well. They open fine in the Falcon standalone app, but they DO require that I have my old-format iLok (thanks again, James) with my MF3 license plugged into my machine to access the patches.
Thus, these are not "free" instruments for people who did not purchase MachFive 3, but just updated MF3 instrument files that appear to be compatible with Falcon and UVI Workstation. …
I had forgotten all about this till I was talking to my son-in-law over breakfast. Now an Apple employee, he was quite the gamer in his youth. I was telling him about a free version of PONG (PING from UVI) and he wanted to get it for his dad. Ok... It's no longer on the current UVI site nor can it be downloaded from the old site that shows up in a Google search. So I fired up the UVI Workstation, found it and it still works. How cool is that? I was able to text it to him along with the other two free games from UVI, Memori and Spark Invaders. I will make these freebies available in my Dropbox account (about 26MB) and will update the ReadMe to show the correct path for current macOS. It's the same as the rest of UVI libraries nowadays: Macintosh HD/Library/Application Support/UltimateSoundBank/UVISoundBanks.
Anyway, while looking at this, I noticed that I had never installed the MachFive3 libraries on my Mac Studio. I remembered this thread and downloaded the current versions dated Dec. 12, 2022 from my MOTU account. They all work great.
Many are redundant now. Having Xtreme 2.0.ufs from UVI, I don't need 1.5 from MOTU. Most or all of the Universal Loops and Instruments have been superseded and I always have my iLok plugged in anyway so that's 5.6GB I can save by dumping MOTU Instruments.ufs.
Re: UVI Workstation
DrewFromKC wrote: Mon Dec 11, 2023 6:42 pm I've been following this thread trying to get my old UVI soundbanks mounted to the newest version of UVI Workstation. I was able to get licenses for my old Plugsound Pro and Xteme FX soundbanks I bought from UVI years ago by providing serial numbers to those products on their website recently. I own MachFive 2 but never upgraded to MachFive 3 when it was still compatible with older Macs. Does this mean I cannot access my old MachFive 2 .ufs soundbanks in the UVI Workstation without upgrading to MachFive 3? (which seems silly since that software is currently incompatible with AS Macs and I would only be upgrading for access to the MachFive 3 soundbank libraries). Any thoughts?
I know this post is a year and a half old and you are unlikely to see it but there's an easy way to find out. Log into your User account on motu.com and go to (your user name) MachFive 2 Registration. Look at the libraries that are available for you to download. If any are dated 12/12/2022 or later, you're in luck. If earlier then you will have to use the older version of the UVI Workstation—there are a few threads on this. Having the later MV3 versions will not make them work if not tied to your iLok.
Many of us have written to UVI Support and successfully asked for a discount on Falcon, myself included. Many of these older MV2 libraries have newer UVI versions. Upgrades and upgrade/sale offers do appear including Vouchers from time to time like the 50% off code a couple weeks ago. I recall that the UVI Portal knew I had Xtreme FX 1.5 from MV3 and I was offered a nice sale price for version 2.0 which I wanted.
