You assume correctly, RME Fireface 800. What I experienced was definitely NOT a sound card issue, it was happening in DP and it seemed to affect one track at a time (although it would change to a different track sometimes if I reloaded the sequence). If I selected the soundbite in the seq editor and hit opt-space it would play by itself and still do it, but if I selected the soundbite in the SB window and auditioned it, it would play back fine.Shooshie wrote:PS: Mr_Clifford, I'm assuming that you do not even have a MOTU audio interface. At least, not a PCI version, correct? So, it would appear that my PCI 424 card's loss of sync with the boxes to which it is connected was just a coincidental continuation of my previous problem,
It may not even be the same bug you had, but it sounded exactly as you described.
A couple of further questions....
How many audio tracks did you have in the session at the time?
Was it doing it on several tracks at once? (ie. over your master bus rather than a single track)
