I did above. Did you miss it?billf wrote:Quite amusing.russhughes wrote:Tell me what you want and I'll send you a disc with the stuff on.
Russ
So I take it that the real answer is that Giga libraries, like the Kurzweil/Akai/EXS libraries I've tried, don't seamlessly import into MachFive, otherwise someone would be able to provide some sort of reference.
I said the Big Fish Audio Orchestral Collection (Giga) imported into Mach Five without a hitch. To add, I've also imported Prime Sounds Session Strings (EXS), Soundscan samples (Akai -- although most are now available in Mach Five native format) and a bunch of old Akai samples acquired over the web. All loaded in easily and perfectly.
The ones that don't import in total without some adjustment, like VSL library stuff, are still very useable (the sounds stay fully intact after all). Just had to do a bit of file finagling after conversion to smooth the work flow.
Mach Five has worked great for me as a "universal sampler." I look forward to version two.
