Yeah ... I'm thinking the same thing. Just wasn't sure if they were supposed to be there for some unknown reason ? I'm really quite MIDI illiterate as I've always worked in Audio only, even with Keys. Although having recently overhauled the Studio and getting the Keylab 88 to accommodate the Arturia Suite virtual instruments I figured I may as well update my knowledge base in regards to MIDI which is needless to say .. Overdue LOLstubbsonic wrote: ↑Mon Aug 12, 2024 12:55 pm In the image showing Audio MIDI Setup, we see the DAW & Updater. I'm tempted to tell you to delete updater, as that just seems like some leftover something. Worst case, if it is needed, you could re-install drivers. The New External Device shows as missing. Do you know what that is? If you don't need it, you can probably get rid of it. Just adding an unnecessary item to the list.
Anyone use an Arturia KeyLa MK2 88 ?
Re: Anyone use an Arturia KeyLa MK2 88 ?
If You Can't Hear It .. Don't Go Near It !!
kolandscapes wrote: ↑Tue Aug 13, 2024 8:54 pmhttps://github.com/gbevin/ShowMIDI/rele ... -1.0.1.zip
