wow...so many replies about this thread - appreciate the effort...
Still, no one has really nailed down the essence of this problem - so, I'll give the few final touches myself in this message, as a gesture, as I've reached to the conclusion that Motu's drivers for windows are substandard compared to the competition, so I've listed the Audio Express for sale (and enjoying my brand new FocusRite 8i6).
Today, after investigating a bit more about Wasapi - I've stumbled into this interesting thread:
http://forum.cakewalk.com/Wasapi-vs-asi ... 93308.aspx
I copy and paste an interesting message from the discussion (message in question limited by "******************":
There are three reasons people tend to recommend ASIO drivers:
1) It is in nearly every case a guaranteed bit perfect delivery. No resampling or anything like that. That is not guaranteed to the same extent in other driver models necessarily
2) Many pro cards have good ASIO drivers and bad WDM drivers. They focus on ASIO since that's what most pro software likes and the WDM drivers are an afterthought. So you get things like MOTU interfaces that can only do one stereo pair via WDM, but all I/O via ASIO.
3) Because that's what most pro software uses so they just assume that's what you have to use. The "that's what we've always used because that's what we've always used," thing.
However that doesn't mean that YOUR card has better ASIO drivers. If it doesn't WASAPI or WDM/KS may well be a better option. For a really well designed card, like a RME, it won't matter what you choose all drivers are equally good and it'll work flawlessly in either mode. For a lot of cards, there is one that works better than the other, and for many consumer cards, ASIO just isn't an option.
They are just different ways of talking to the card, so you use the one that is right.
read it?
Each line of this message is pure gold - read it 2 or 3 times until it make sense to you (thanks to Sycraft) it is worth the whole lot of this discussion...note also the reference to Motu when citing bad drivers for Windows - he doesn't mention Focusrite or Maudio or else but Motu! Note also the RME comment. This guy is spot on.
Then, as another kind gesture - since someone wanted to open another can of worms related to the utility of 24bit v 16bit in terms of audio appreciation - like saying...it doesn't really matter?!
During my Audio Engineering course (15 odd years ago) I had the chance to determining first hand about the audible differences when listening 16bit v 24bit or even 32bit audio - it does matter especially if you have the right hardware - and you don't need to spend thousands to hear the difference a good quality mid range Beyerdynamic or Sennheiser headphones would do.
Personally, when listening to a 24bit audio the dynamic is creamier smoother - the high frequencies (hi-hats release in particular) sounds crispier and smoother (no antialiasing) there is more room for each frequency to "breath" into each own slot (not crammed together with other sounds/instruments) because the dynamic range is wider (this is what 24bit does). Even if the Bit resolution is directly related to amplitude - but indirectly affect also the frequency response (which is directly covered by the sampling rate) but the 2 (sampling rate and bit resolution) work in synergy to define the audio quality - to say 16bit and 44khz is all you need is wrong in numerical/technical terms and at most it represent a subjective statement if you don't care or never really bothered to check (mind you some prefer the grunginess of 8 bits too - lofi).
Now, there are plentiful of websites where people can download 24bit or other types of HiRes Audio (DSD, 32bit and others) - and these are becoming more and more popular - there must be a reason for it...now download a few 24bit tracks and compare them to the 16bit version - if you don't hear any difference blame it on your Motu inability to address the 24bit to Windows WDM or Wasapi drivers or else load these tracks on your DAW and use the Asio drivers!! silly as it sounds this is the solution according to Motu's design? (not very practical is it?).
Another final nail to the coffin...
I've experimented with a Mac recently (my main PC is a Windows) - all the other audio interfaces I have at the moment (FocusRite 8i6, Edirol UA 4-FX, MAudio Audiophile 192) do show all the available sample rates and bit resolutions declared on the specs on both Windows and Mac - so if the Audiophile offers 32bit and 192khz on Windows it does also offer the same on a Mac (as expected because the hardware is the same). The Motu Audio Express instead shows only 16bit and 44khz and 48khz on Windows, while on Mac it shows all the available sample frequencies on the specs, so up to 96khz (and only 16bit...at least in this sad limitation is consistent). So why does the Motu show different options on a Mac? BAD DRIVERS!!...it is unacceptable that the hardware capabilities of an audio interface are limited by the drivers...and if anyone doesn't understand the implications then re-read the message until it make sense.
Case closed (amen).
