DP 10.1 out
FMiguelez
Re: DP 10.1 out
Post by FMiguelez »
mrgkeys wrote:this is the largest bug list fix I have ever seen from DP. It's 5 pages long!
It's huge!
I think there's a bug in the bug list fix... :shake:
dix
Re: DP 10.1 out
Post by dix »
tremo wrote:
dix wrote:Because I have no self-control I went ahead and updated to DP 10.1 . While I'm happy to report that the export options, mentioned above are still available in 10.01, I'm extremely sorry to report that none of my MOTU plugins are available in DP10.01 :(
dix, are the old plugins (.bundle files) still in the Library/Audio/Plugins/MAS folder?
Not in the User Library. They're in the System Library. ...where they've always been, right?
tremo
Re: DP 10.1 out
Post by tremo »
Yep.
Mac Studio Max M1 | 32GB | 15.3 | 828es | M4 | DP 10.13 | Studio One 7 | Logic 11
dix
Re: DP 10.1 out
Post by dix »
Also, I can no longer Option-drag to zoom on the SE or the ME. Anyone find a way to get that back?
...There's lots of new wonderfulness to talk about. Arguably more than the DP10 upgrade, but I'm trying to get up and running as I'm accustom to.
terrybritton
Re: DP 10.1 out
Post by terrybritton »
For Windows users, the certificate issue is still there if you attempt to run the uninstaller, so we are stuck with having both 10.01 and 10.1 residing together until they fix it.
With this huge a bugfix list, I'm installing it anyway!!! :-)
Terry
MOTU 828 mk3 hybrid
Re: DP 10.1 out
Jumped in head first here. Initial spin around the block seems okay, but damn, does there seem to be a lot of wasted space at the top of the tracks overview? Anyone know if this can be changed?
828x MacOS 14.7.6 M1 Studio Max 1TB 64G DP11.34
mrgkeys
Re: DP 10.1 out
Post by mrgkeys »
the scrolling behavior is MUCH improved. Feels great without touching the scrolling pref pane. I love love love the square MIDI note display. uncheck those round edges right out of there. Lots of new Color options besides the Selection color, Clip color, Memory Cycle Color, Memory Play Color, auto record color...
Re: DP 10.1 out
cuttime wrote:"Digital Performer is always capturing MIDI input, even when the main transport is not recording."
As I recall, Hybrid Arts SMPTE Track used to do this.
You recall correctly. It would also fill the MIDI BUFFER and unload it with a bang if the transport wasn’t moving. All doodling was placed at a single point in time. A glorious noise if you’re into that sort of thing. Lol
terrybritton
Re: DP 10.1 out
terrybritton wrote:For Windows users, the certificate issue is still there if you attempt to run the uninstaller, so we are stuck with having both 10.01 and 10.1 residing together until they fix it.
Terry
Mryon reminded me of the fix. I set the system clock back to September and the uninstall went smoothly, then set it back again. I did have to run the 10.1 modify and repair tool from the Apps and Features page to fix a welcome window glitch, though.
[EDIT] Modify/Repair wasn't enough - the welcome screen was still broken. So, lesson learned - Uninstalling 10.01 first (AND 10.1 if you had installed it) and reinstalling 10.1 is necessary.
I just did it on my other machine and uninstalled 10.01 (setting the date back to September) first, then installed 10.1 without issue.
Terry
MOTU 828 mk3 hybrid
Michael Canavan
Re: DP 10.1 out
Post by Michael Canavan »
Logic has had Capture Last Take as Recording forever, and I welcome this in DP!
Oh and while no Chunk folders, there is Chunk colors now. At least I can establish a color for various Chunks to help sort...
Re: DP 10.1 out
AFTERTOUCH BUG CONFIRMED FIXED yes, I know I was shouting. AND VELOCITY HANDLES ARE MUCH BETTER
bralston
Re: DP 10.1 out
Post by bralston »
Was told folks will also find that the VIs do not need to be reloaded when Hardware settings / bundles change. Something not on the feature list...but welcomed.
Regards,
Brian Ralston
Re: DP 10.1 out
bralston wrote:Was told folks will also find that the VIs do not need to be reloaded when Hardware settings / bundles change. Something not on the feature list...but welcomed.
Awesome
Michael Canavan
Re: DP 10.1 out
cuttime wrote:AFTERTOUCH BUG CONFIRMED FIXED yes, I know I was shouting. AND VELOCITY HANDLES ARE MUCH BETTER
Honestly even better than the improvements in velocity handles, the new Velocity Tool (v key command) is fantastic! :love:
SMS
Re: DP 10.1 out
Post by SMS »
:dance: Goodie! The aftertouch issue seems fixed, and MX4 is working again for me. It's been broken a while for me, likely a plug-in conflict issue or something, troubleshooting it has been on my 'to-do' list for quite a while, so WHEEE!
I'll have to get used to the new velocity display in the MIDI editor---
UPDATE
...Just checked out the new Velocity tool. I think I get it, but I don't see any advantage over the tools we already have. Currently I just select notes in the piano roll area, then drag the velocity handles up or down (in the area below). Usually with shift to restrain to vertical movement. I use Control-drag a lot to compress or expand velocities and controller streams.... that doesn't seem to work with the new V tool. What I B missin'?
MOTU user since Performer™ 1.22 on 128k floppy
DP 11.23
MacBook Pro 14” 2023 M2 max 12 core
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
