It's huge!mrgkeys wrote:this is the largest bug list fix I have ever seen from DP. It's 5 pages long!
I think there's a bug in the bug list fix...
Not in the User Library. They're in the System Library. ...where they've always been, right?tremo wrote:dix, are the old plugins (.bundle files) still in the Library/Audio/Plugins/MAS folder?dix wrote:Because I have no self-control I went ahead and updated to DP 10.1 . While I'm happy to report that the export options, mentioned above are still available in 10.01, I'm extremely sorry to report that none of my MOTU plugins are available in DP10.01
Yep.dix wrote:Not in the User Library. They're in the System Library. ...where they've always been, right?tremo wrote:dix, are the old plugins (.bundle files) still in the Library/Audio/Plugins/MAS folder?dix wrote:Because I have no self-control I went ahead and updated to DP 10.1 . While I'm happy to report that the export options, mentioned above are still available in 10.01, I'm extremely sorry to report that none of my MOTU plugins are available in DP10.01
You recall correctly. It would also fill the MIDI BUFFER and unload it with a bang if the transport wasn’t moving. All doodling was placed at a single point in time. A glorious noise if you’re into that sort of thing. Lolcuttime wrote:"Digital Performer is always capturing MIDI input, even when the main transport is not recording."
As I recall, Hybrid Arts SMPTE Track used to do this.
Mryon reminded me of the fix. I set the system clock back to September and the uninstall went smoothly, then set it back again. I did have to run the 10.1 modify and repair tool from the Apps and Features page to fix a welcome window glitch, though.terrybritton wrote:For Windows users, the certificate issue is still there if you attempt to run the uninstaller, so we are stuck with having both 10.01 and 10.1 residing together until they fix it.
With this huge a bugfix list, I'm installing it anyway!!!
Terry
Logic has had Capture Last Take as Recording forever, and I welcome this in DP!MIDI Life Crisis wrote:You recall correctly. It would also fill the MIDI BUFFER and unload it with a bang if the transport wasn’t moving. All doodling was placed at a single point in time. A glorious noise if you’re into that sort of thing. Lolcuttime wrote:"Digital Performer is always capturing MIDI input, even when the main transport is not recording."
Awesomebralston wrote:Was told folks will also find that the VIs do not need to be reloaded when Hardware settings / bundles change. Something not on the feature list...but welcomed.
Honestly even better than the improvements in velocity handles, the new Velocity Tool (v key command) is fantastic!cuttime wrote:AFTERTOUCH BUG CONFIRMED FIXED yes, I know I was shouting. AND VELOCITY HANDLES ARE MUCH BETTER
