dix wrote:I can't tell. Are the new Mac Pro's processors user-upgradable? I didn't hear that specifically in the Keynote, but the way it's listed on the Apple site it implies that they might be.
There are videos showing that the iMac Pro can be upgraded with off-the-shelf Intel CPUs. No reason to think that the Mac Pro will be any different.
dix wrote:...no one seems to have direct knowledge, but I've seen speculation that a fully loaded new Mac Pro could be as much as $35,000.
Since the competition can cost as much as $150,000 + monitor, I bet not. Ok, there are a few big differences—the top of the line Maya boxes are using pairs of the Platinum 8180 @ $11,000 ea to get 56 cores. Apple will probably use the 3175X with a $treet of $3k—a quite similar CPU but it can't be ganged with another 28 core. This means that 28 is the max with the first release (I expect higher available core counts within two years). Even still, I think that $35K for a tricked out 7.1 is wishful thinking.
This guy speculates $50K. Without having any idea the price of some of the hot-rod options, all I can say is
maybe...
https://www.zdnet.com/article/how-much- ... 8614594477
But knowing what's out there now, it's not too hard to come up with estimates for one of the middle ground machines.
The 256GB SSD storage minimum tells us it's the same media as the Mini as are the 512G/1T/2TB options. The iMac Pro uses the same SSDs but 1/2/4TB. Except for the 256GB, these are pairs set up in RAID 0 (sort of) controlled by the T2. The upgrade prices should be 512G-$200, 1T—$600, 2TB—$1,200, 4TB—$2,400
2666MHz DDR4 RAM — again, same as the Mini and iMac Pro. Upgrade prices from Apple should be $400/2,000/5,200 for 64/128/256GB respectively. With 12 slots available instead of 4 for the iMP, it's easy to do the math. OWC has the 64GB modules — 768GB (64G x12) will run $6,837. The 24 & 28 Core take faster RAM and can handle 128G sticks as referenced in the article.
GPU for the base model is the 580x — really is enough for DP. The Vega Pro II and Pro II Duo have been announced but they won't be inexpensive. Based on what is out there now, I'll be surprised if the price is much less than $2,000 for the Radeon Pro Duo or under $4,000 for the Radeon Pro Duo II, perhaps more.
Based on the above, the 16 core Mac Pro that specs out close to my 14 core iMP should run around $9,400 + monitor. BTW, no one is saying that you need the new $5,000 monitor if you aren't doing really high end graphics, film or animation. Stay with the 580x and a 5K LG ($1,300 for the 27"–$1,500 for the 34") and it comes in under $9,000 by my estimate.
https://www.lg.com/us/4k-monitors
My iMP, by comparison is $9,749 or $8,289 in the Refurb Store (14 Core 128G RAM 2T SSD Vega 64). I was about to spend around $7,300+$675 tax on a Refurb (10 core 64G 2T Vega 56) when I found mine used for less including AppleCare.
I posted a video awhile back that compared a 12 core 6.1 Mac Pro and a 10 core iMac Pro. The file was 150 and 300 tracks of Logic Pro, each with a an instance of a VI and two CPU intensive plugins. The 6.1 could handle it but there was some track stealing going on. The iMP wasn't breathing hard. The keynote showed the new New Mac Pro running 1,000 tracks of VIs in the next version of Logic but we don't know how beefy the MP running the demo is.
I don't think the 7.1 is overpriced at all. Pretty certain I'll not need one but
never say never, right?
