Copying DP Mixes leading to bad copies of mixes...Bug?
Dan Worley
Re: Copying DP Mixes leading to bad copies of mixes...Bug?
Post by Dan Worley »
MapleGuitar wrote:I know this is an old thread, but the problem still exists in DP 8.05.
When I choose Duplicate Mix from the little pop-up menu at the bottom of the Mixing Board window, I can see faders move as soon as the new mix-copy name appears in the pop-up menu.
It doesn't happen every time; but, I'm concerned that we don't know what else may be changing when a mix is duplicated (such as plug settings).
Does anybody know a fix or workaround?
I haven't had that problem here, but I'll sure look out for it.
I guess the workaround would be Project > Sequences > Duplicate Chunk, or do a Save As and work in the new file.
DP10.13
