IR Reverb
jloeb
Post by jloeb »
monkey man wrote:
Shooshie wrote:...
The Altiverb plug cannot be assigned as an "open with" application, 'cause the finder doesn't see it as such.
I think this is the trick - in the "open with" browsing window, did you change the option up top from "recommended applications" to "all applications"? In theory, that should let you choose PacMan as the application you want to open the files with, should you for some reason wish to do such a thing.
monkey man wrote:Whilst I haven't actually heard the results, a brief test of that old demo confirmed that the Unix files at least do appear to load.
Wassup wit' dis, propellor-head 'Cornies? :?
Correction. I'm afraid they don't load. :cry:
monkey man wrote:The Altiverb plug cannot be assigned as an "open with" application, 'cause the finder doesn't see it as such.
Dragging the files into DP's soundbites window doesn't work.
jloeb wrote:I think this is the trick - in the "open with" browsing window, did you change the option up top from "recommended applications" to "all applications"? In theory, that should let you choose PacMan as the application you want to open the files with, should you for some reason wish to do such a thing.[
My thinking exactly, jloeb; thank you for that.
The thing is, the plug-in is not seen as an application, so is greyed out even when "show all applications" is chosen.
I've been very ill and off the board for a spell; sorry for the slow response.
Just popped in to change my avatar as it's the start of a new month, but I really shouldn't be here. :wink:
