Michael Canavan wrote: Sun Feb 20, 2022 9:21 pm Blue Cat Audio released an essentially Rewire etc. replacement plug in.
What's it called?
Michael Canavan
Post by Michael Canavan »
James Steele wrote: Sun Feb 20, 2022 10:23 pm
What's it called?
Lol that was dense of me, it's called Connector.
https://www.bluecataudio.com/Products/P ... Connector/
So far the audio routing works just fine, but the MIDI is a little iffy. I can get audio from MainStage with Alchemy etc. into the track in DP, but sending MIDI notes recorded in DP is not really working. Sent in a support ticket. I suspect you would have to still use the IAC MIDI driver in Mac OS to do this right.
It routes audio from one application to another, over a network like VEP, and does MIDI as well.
So essentially I can use Alchemy hosted in MainStage inside DP. :woohoo:
Just got it, but everything checks out so far. On sale for 20% off until midnight... but it's only around $50 normally so...
Does it compensate for latency across the connected apps? I can do this with IAC and blackhole, but need workarounds to deal with the differences in timing between things that get done in DP and things that take the round trip.
I’m beta testing the M1 native version of a certain notation app beginning today. This will be most useful if I can get it to work.
The last updates to GB, Logic, FCPx and MainStage appear to have removed all ReWire components.
Michael Canavan
So far I have gotten Alchemy hosted in Logic inside DP11, MIDI and audio! :woohoo:
So far I have not been able to get MIDI from DP11 to Mainstage though. :smash:
If anyone is curious you host a send and recieve VST on an Aux track in DP, then send the out of a MIDI track to the Connector instance in the Aux track.
In Logic you host a receive plug in in the MIDI FX slot on the Alchmey instrument track, then another instance of Connect as a Send in the regular Audio FX slot. One thing, it would be smart to send beat clock to Logic so the arpeggiators etc. are in time.
I have DP 11 working as a ReWire Slave on my M1 MBAir, both native and Rosetta 2. Haven't tried the others yet.
London Symphonic Strings $39
I haven't searched YouTube yet for reviews on this product, but ADSR has this for sale for $39 until March 1. Normally $399. 42GB worth of samples. They talk it up quite a bit on the website, but who knows, right? Again... I need to do some investigation. Requires full version of Kontakt.
https://www.adsrsounds.com/product/soft ... nstrument/
Michael Canavan
mikehalloran wrote: Mon Feb 21, 2022 5:48 pm I have DP 11 working as a ReWire Slave on my M1 MBAir, both native and Rosetta 2. Haven't tried the others yet.
This is a whole can of worms, but DP has never been able to be a Rewire slave. You must be referencing something else, or maybe DP as master.
bx_limiter True Peak (and others) for $29.95
Plugin Alliance usually excludes bx_limiter True Peak from their sales but it’s available right now for $29.95. Code ANY-2999-1 and is good up to three products. There are always some restrictions but True Peak is finally off that list. Since I bought it, I no longer use MW Limiter which distorts when pushed hard.
Their bundles, packages and licensing are confusing as hell but it is possible to purchase permanent licenses for single plugs and VIs.
https://www.plugin-alliance.com/en/products.html
Re: bx_limiter True Peak (and others) for $29.95
Post by Rick Cornish »
mikehalloran wrote: Sat Feb 26, 2022 1:03 pm Plugin Alliance usually excludes bx_limiter True Peak from their sales but it’s available right now for $29.95. Code ANY-2999-1 and is good up to three products. There are always some restrictions but True Peak is finally off that list. Since I bought it, I no longer use MW Limiter which distorts when pushed hard.
+1 on bx_limiter True Peak. That’s a bargain. It’s the last thing on my master buss n every mix.
Re: True Peak
+ another one for True Peak.
It was on my wishlist from the day it dropped 'til I managed to snag it a year or so later.
Nobody seems to have a bad thing to say about it. It's like the bx_Limiter but more-transparent from what I can gather.
Thanks for the heads up. I snagged it. I like the GUI, and it all makes sense pretty fast.
It's kind of funny, P.A. has these sales that make it sound like "any" (as in "ANY-2999-1") of their products are included. Just note that even though Gig Performer is listed, it's not eligible. I was just thinking for $30, GP might be a nice alternative to a mainstage or plogue type host. Alas.
It's cool to hear the big shots praising True Peak, then to score it for $30.
stubbsonic wrote:Thanks for the heads up. I snagged it. I like the GUI, and it all makes sense pretty fast.
Me too!
Izotope R4 Reverb. $9.99. Was $299.00 ($289.01 off)
Here’s the sale page. You have to scroll down to find it: https://www.izotope.com/en/shop/paid-deals-2.html
R4 delivers the historic warmth of time-tested reverb hardware units with CPU-efficient reverb and expanded creative control. Add personality and space to your music with reverb designed to color your mixes without compromising clarity.
NOTES:
• You can't install via the Izotope Product Portal, you need to download from your products page when you're logged in.
• I think iLok is the only authorization type available which is fine by me, BUT if you're like me and want to sure an authorization ends up on your iLok dongle and NOT the computer, DO NOT redeem the iLok code with iLok Manager prior to downloading and installing. This bit me on the butt with another of these Exponential Audio plugs, and I had to authorize my computer AS WELL as the iLok dongle, because the plug-in upon first load did not see the authorization on my iLok and put me in a Catch 22 where if I tried to authorize again for iLok it would tell me it was already there, but still wouldn't let the plug run. I had to use computer authorization.
• Bottom line: Install the plug first before redeeming iLok code. You may need to restart your Mac for it to recognize new AU plug. Launch DP and when DP verifies the plug, you will THEN be prompted to enter the serial number to put authorization on your iLok and be prompted if you want authorization on your Mac or your iLok dongle. I always choose the dongle personally.
Re: PSP Impressor
PSP Impressor, normally $99, is on-sale:
Intro price $69
If you own MixPressor, $20.70
https://www.pspaudioware.com/products/psp-impressor
It's a souped-up version of MixPressor, essentially, but a Helluva-lot better.
Here's the comparison between the two:
The most obvious difference between PSP Impressor and it’s predecessor, PSP MixPressor, is its new GUI, but PSP Impressor offers many more enhancements and new goodies than just a new interface. PSP Impressor features many refinements in sound quality that make it a vital tool for the future of audio production.
Here’s a list of innovations in PSP Impressor:
New high resolution, scalable GUI.
VST3 support.
FAT quad sampling option.
Entire compression engine runs at internal quad sampling for proper compressor modelling when FAT is disengaged and 16 x sampling when the FAT is engaged.
High sample rate support up to 400kHz.
Feedback and feedback + feedforward compression modes, PSP MixPressor runs only in feedforward mode.
New side chain filter modes: HPF and Equal Power. PSP MixPressor only had its powerful Bell type side chain filter, however HPF gives PSP Impressor a more classic touch, and the Equal Power results in extremely transparent and well balanced compression of complex tracks, drum groups or even entire mixes.
Four Auto Attack and four Auto Release modes instead of just two modes for each.
Refined compression Shapes for added versatility.
Adjustable Auto Makeup mode.
Adjustable channel Link.
Input (Pre) and output (Post) meter modes with optional Compare mode.
Adjustable VU reference level.
Adjusted ranges for most of knobs to make them more user-friendly.
Input - Output knobs’ link.
New output Limiter.
Other algorithm refinements to make the PSP Impressor the natural tool of a choice for vocals, drums, acoustic guitars and other tracks, groups, and even during the mastering process.
