Well, for one that comes to mind, there is a menu that opens in Logic with a click-hold of the mouse that allows access to the all parameters in FabFour-- but they appear in a Logic menu for a different purpose.zed wrote: Can you please give me an example, or two, of a FabFour menu that appears in Logic but not in DP? Thanks.
In both apps, you *can* access these parameters in FabFour VIEW menu, but the nice thing about Logic is that from its own "mirror" sticky menu, you can see the parameter as ADT or Reverb, etc. (by name). All you have to do here is select the parameter name for which you want to record automation data and off you go.
It's not impossible in DP, but because of the limited AU handshaking, you must first figure out the particular CC# that is pre-assigned to ADT and other parameters, then you must set DP to record by that number (and not by the parameter name). With 20+ parameters in a project, it's a LOT easier to select-assign-record-switch-record-swith-record... different automation parameters with less thought and fewer steps.
Of course, the downside in Logic is that setting up a multi-timbrel instrument is a royal nightmare, whereas DP easily wins in this department. It's really a wild trade off.
That's why I say that if DP6 does a similar kind of AU handshaking that Logic does and retains its current manner of setting up multi-timbrel instruments, then that alone will make upgrading to DP6 worth it.
