DP 10.1 out
Re: DP 10.1 out
philbrown wrote:Do Option + Right and left arrow still work to incrementally zoom in and out? I use that so much, it would probably be a dealbreaker for me if that no longer worked.
I use Command Arrow, not Option Arrow, but I probably set that in the Command window, and had DP retain the custom commands on its first startup. I assume you could do the same.
Re: DP 10.1 out
Pinch zoom on the trackpad will speed things up for those of us who gave up using a potato (I mean mouse - I meant potato) for a MTP2.
terrybritton
Re: DP 10.1 out
Post by terrybritton »
I've put Admiral Bumblebee's quick overview of DP 10.1 improvements over at the tutorials section, as it is very helpful.
Terry
MOTU 828 mk3 hybrid
Re: DP 10.1 out
MIDI Life Crisis wrote:Pinch zoom on the trackpad will speed things up for those of us who gave up using a potato (I mean mouse - I meant potato) for a MTP2.
Yep, I can’t imagine ever using a mouse again. The Magic Trackpad 2 is an incredible piece of hardware.
:brucelee:
wheever
Re: DP 10.1 out
Post by wheever »
Is anyone else seeing higher CPU usage on 10.1?
I just updated from 9.5x, and a tune I was working on is now choking, when it wasn't before. Nothing else has changed in the system or sequence.
Granted, this particular tune was close to maxing out at 2048 buffer size, but on 10.1, it just barfs unless I turn off the absurdly CPU spendy IK tape machines. It played fine before.
Anyone else seeing this?
Performer user since--HOLY CR*P--1986? YIKES!
Re: DP 10.1 out
wheever wrote:Is anyone else seeing higher CPU usage on 10.1?
Yes. Enabling MachFive3 maxed the CPU meter and made the cursor jerky.
wheever
Re: DP 10.1 out
Post by wheever »
Well, that's a drag.
My comp is saying 18% total processor usage, but DP is saying it's maxed out. About half the cores aren't even being utilized. I'll never understand the DP processor meter, or why it doesn't use all available cores.
And thus it has always been. :banghead:
cojoncio
Re: DP 10.1 out
Post by cojoncio »
10.1 takes longer to load my (fairly big) template. Also moving tracks and folders takes longer as well, including spinning balls. None of that happened before in 10.01 and 9.52
Mac Studio Ultra 128 RAM-Ventura
Hackintosh i9-128 RAM-NVMe and SSD drives-Monterey
PC i9-256 RAM-NVMe and SSD drives-Windows 10
828es-828-mk2-ADA8000
VEP7, some nice libraries and some nice hardware synths
Re: DP 10.1 out
wheever wrote:Well, that's a drag.
Yes, it’s been like this as long as there has been a cpu meter. I don’t understand why it’s not fixed.
mancave59
Re: DP 10.1 out
Post by mancave59 »
Anybody else having issues with retrospective MIDI ? MIDI recording works fine but when clicking on Region->retrospective MIDI all I get is mono-pressure, no note data
Thanks !!
Mac Mini OSX 10.14.6 3.2 GHz Intel Core i7 64 GB RAM
DP 10.1
Pro Tools Ult 2019.6
Nuendo 10.2
Cubase Pro 10.5
Logic Pro X
BobK
Re: DP 10.1 out
Post by BobK »
Holy cow! I just discovered 10.1, and I'm impressed. Lots of features for a .1 release.
I've been wanting (and requesting) MIDI clips for years. Nice to finally see them. And the ability to un-group them is cool.
GUI improvements. Zoom with trackpad. Velocity tool. MIDI editing improvements. Yay!
Thanks, MOTU!
Bob
M1 Max Mac Studio - 64 GB RAM - macOS 15.4
MacBook Pro (15-inch, Mid 2012) - 2.6 GHz Intel Core i7 - 16 GB RAM - macOS 14.4 via Open Core Legacy Patcher
DP 11.23
Metric Halo ULN-8 mk4
BobK
Re: DP 10.1 out
Post by BobK »
“Pinch to zoom” on my Magic Trackpad (1st gen) isn’t working. It should, per page 331 of the User Guide.
Anyone getting this to work?
Bob
DP 11.23
labman
Re: DP 10.1 out
Post by labman »
Phil O wrote:
terrybritton wrote:
Phil O wrote:OK, so I got it to work in a newly created project by not using one of my existing templates, but the bug remains.
Phil
Hey there Phil. Are your templates created as DP templates, or just regular DP files you have built from scratch and are using as a template? Thanks
labman
Re: DP 10.1 out
Post by labman »
We need to do the metering trick we used 40+ years ago. Just put tape over the stinking DP CPU meter so we cant see it. Anyone got any digital masking tape?
wonder
Re: DP 10.1 out
Post by wonder »
Small bug I noticed.
When dragging the right end of a MIDI note to extend it, the MIDI note moves to C3 until you let go of the note. When you release it, it moves back to its original pitch.
This is for a single note drag/extension.
